This idea is based on this Blueprint. When you scan a NFC tag the specified music will be played. Unlike the original Blueprint I added the ability to select from various streaming services:
- Spotify
- Amazon Music
- Deezer
- TuneIn
- Universal: Enter the command you would say to your Echo device e.g. “Play my playlist Oldies on Spotify”. Requires Alexa Media Player version 3.4.0 or newer.
Because the tag ids cant be accessed by the selectors, you have to copy the ID from the NFC-Tags settings of your Home Assistant Instance.
I personally only use the Universal and Spotify streaming service. If you use the others and find something out about formatting the song name, please let me know so i can add them to the description.
Requirements:
- Alexa Media Player installed (install it from HACS)
- The according streaming service must be configured as an Alexa Skill inside your Alexa account
blueprint:
name: Start music on Alexa Media Player when a NFC-tag is scanned
description: |
## Introduction
When a tag is scanned, start the associated music on the selected Alexa media player.
You can select from various streaming services or run your own commands with the "universal function".
## Supported Streaming Services
### Spotify
Song name must be songname (e.g. Still Alive),
songname and interpret (e.g. Still alive from Red ),
"playlist" and playlist name (e.g. Playlist Oldies)
or the name of a featured playlist from Spotify (e.g. Missed Hits).
### Universal
You can put a command in the songname which you would say to your Alexa device e.g.
"Play my playlist Oldies on Spotify" (leave out your trigger word from your device).
### Amazon Music, Deezer and TuneIn
This should work as well, but I don't use them personally, so I cant say much abaout how to enter
the song title. If you use them and know how to format them, please inform me so I can add it to the description.
domain: automation
input:
tag_id:
description:
The tag ID of your NFC trigger. Can be found under Settings --> NFC Tags
and then click on the NFC Tag you want to choose.
alexa_entity_id:
description: The entity ID of the alexa player to use
selector:
entity:
domain: media_player
source:
description: Streaming service which should play your music
default: Spotify
selector:
select:
options:
- Amazon Music
- Spotify
- Apple Music
- Deezer
- TuneIn
- Universal
volume:
description: Volume of the playback. 0 for 0% to 1 for 100%. E.g. a volume of 40% would be 0.4.
selector:
number:
min: 0
max: 1
step: 0.01
song_name:
description:
The name of the song to play. Look at the description of the Blueprint
to see the right formatting for your specific Streaming service.
shuffle:
default: False
selector:
boolean:
variables:
source: !input source
alexa_entity_id: !input alexa_entity_id
song: !input song_name
- platform: tag
tag_id: !input tag_id
- service: media_player.volume_set
volume_level: !input volume
- service: media_player.shuffle_set
shuffle: !input shuffle
- service: media_player.play_media
data_template:
media_content_id: !input song_name
media_content_type: >
{% if source == "Universal"%}
custom
{% elif source == "Apple Music" %}
APPLE_MUSIC
{% elif source == "Amazon Music"%}
AMAZON_MUSIC
{% else %}
{% filter upper %}
{{source}}
{% endfilter %}
{% endif %}
Changelog:
- 9 May 2021: Added volume as an input
- 17 May 2021: Added input for shuffle mode
