Logs for Unavailable DLNA Digital Media Renderer
2024-10-04 15:08:57.948 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration mass which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-04 15:08:57.948 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration scheduler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-04 15:08:57.949 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-04 15:08:57.949 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration versatile_thermostat which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-04 15:08:59.495 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_default_certs with args (<ssl.SSLContext object at 0x7fccd93baf50>, <Purpose.SERVER_AUTH: _ASN1Object(nid=129, shortname=‘serverAuth’, longname=‘TLS Web Server Authentication’, oid=‘1.3.6.1.5.5.7.3.1’)>) inside the event loop by integration ‘freebox’ at homeassistant/components/freebox/init.py, line 26: await api.open(entry.data[CONF_HOST], entry.data[CONF_PORT]) (offender: /usr/local/lib/python3.12/ssl.py, line 713: context.load_default_certs(purpose)), please create a bug report at Issues · home-assistant/core · GitHub
For developers, please see Blocking operations with asyncio | Home Assistant Developer Docs
File “”, line 198, in _run_module_as_main
File “”, line 88, in _run_code
File “/usr/src/homeassistant/homeassistant/main.py”, line 223, in
sys.exit(main())
File “/usr/src/homeassistant/homeassistant/main.py”, line 209, in main
exit_code = runner.run(runtime_conf)
File “/usr/src/homeassistant/homeassistant/runner.py”, line 189, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File “/usr/local/lib/python3.12/asyncio/base_events.py”, line 674, in run_until_complete
self.run_forever()
File “/usr/local/lib/python3.12/asyncio/base_events.py”, line 641, in run_forever
self._run_once()
File “/usr/local/lib/python3.12/asyncio/base_events.py”, line 1990, in _run_once
handle._run()
File “/usr/local/lib/python3.12/asyncio/events.py”, line 88, in _run
self._context.run(self._callback, *self._args)
File “/usr/src/homeassistant/homeassistant/setup.py”, line 165, in async_setup_component
result = await _async_setup_component(hass, domain, config)
File “/usr/src/homeassistant/homeassistant/setup.py”, line 461, in _async_setup_component
await asyncio.gather(
File “/usr/src/homeassistant/homeassistant/setup.py”, line 463, in
create_eager_task(
File “/usr/src/homeassistant/homeassistant/util/async_.py”, line 45, in create_eager_task
return Task(coro, loop=loop, name=name, eager_start=True)
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 742, in async_setup_locked
await self.async_setup(hass, integration=integration)
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 594, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/freebox/init.py”, line 26, in async_setup_entry
2024-10-04 15:08:59.507 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_verify_locations with args (<ssl.SSLContext object at 0x7fccd93baf50>,) inside the event loop by integration ‘freebox’ at homeassistant/components/freebox/init.py, line 26: await api.open(entry.data[CONF_HOST], entry.data[CONF_PORT]) (offender: /usr/local/lib/python3.12/site-packages/freebox_api/aiofreepybox.py, line 78: ssl_ctx.load_verify_locations(cafile=cert_path))
#load_verify_locations
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
create_eager_task(
2024-10-04 15:08:59.509 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to open with args (PosixPath(‘/config/.storage/freebox/mwfvdaik_fbxos_fr.conf’), ‘r’) inside the event loop by integration ‘freebox’ at homeassistant/components/freebox/init.py, line 26: await api.open(entry.data[CONF_HOST], entry.data[CONF_PORT]) (offender: /usr/local/lib/python3.12/site-packages/freebox_api/aiofreepybox.py, line 255: with open(file, “r”) as f:)
#open
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
create_eager_task(
2024-10-04 15:09:01.846 WARNING (MainThread) [async_upnp_client.profiles.profile] Failed (re-)subscribing to: uuid:10e3aa05-fe36-4151-9182-af17812517a8, reason: UpnpConnectionError(“ServerDisconnectedError(‘Server disconnected’)”, None)
2024-10-04 15:09:01.882 WARNING (MainThread) [async_upnp_client.profiles.profile] Failed (re-)subscribing to: uuid:b063f20c-a35a-4656-b83a-f275a95f76ff, reason: UpnpConnectionError(“ServerDisconnectedError(‘Server disconnected’)”, None)
2024-10-04 15:09:01.901 WARNING (MainThread) [async_upnp_client.profiles.profile] Failed (re-)subscribing to: uuid:81411230-baaf-4537-a5a1-2602ce867c45, reason: UpnpConnectionError(“ServerDisconnectedError(‘Server disconnected’)”, None)
