I can play playlist from Spotify from hass, but how can i start playing a playlist with songs in random order. At the moment when i start a playlist is is the same order every time.
can be deleted found solution on forum after posting, sorry for spamming
where did you find the solution. I also need a solution it starts the playlist every time with the same song. (even i have added shuffle: true, it also doesn’t matter at what point in the script i set it to true it will always start with the same song)
I answer on this old topic to share my solution.
I also had the issue that the playlist was always started by the same sing. I just added a Wait of 1s and then it works.
Hope this helps someone.
