Hello everyone !
So i faced an issue with mopidy integration.
Situation
I want to play Tidal playlist on my mopidy especially for my wake up alarm.
Unfortunatly, HACS mopidy integration doesn’t seems to work well with them.
Solution
A pyscript. (AppDaemon would be like kill a fly with a bazooka.).
Here is the pyscript :
import requests
from homeassistant import config_entries,helpers
from homeassistant.helpers import entity_registry as er
def mopidy_rpc(host, method, params=[]):
# def mopidy_api(host, method, params=None):
""" Call mopidy api """
api_host = "http://" + host + ":6680/mopidy/rpc"
msg = {"jsonrpc": "2.0", "id": 1, "method": method, "params": params}
return task.executor(requests.post,
api_host,
headers={"content-type": "application/json"},
timeout=20,
json=msg
@service
def mopidy_load_playlist(play_a_tracklist):
"""yaml
name: Load Mopidy Playlist
description: Get a mopidy playlist and inject songs in tracklist
fields:
play_a_tracklist:
name: Choose and play a tracklist
description: Chose and play a tracklist on a defined mopidy player
exemple: "play_a_tracklist: {host: 127.0.0.1, media_content_id: tidal:playlist:c5975061-a57b-4e23-be66-8bb11946ae42 }"
required: true
selector:
media:
# Get all informations
# 1. host
entity_reg = er.async_get(hass)
entry = entity_reg.async_get(play_a_tracklist.get('entity_id'))
host = hass.config_entries.async_get_entry(entry.config_entry_id).as_dict()['data']['host']
# playlist_id
playlist_id = play_a_tracklist.get('media_content_id')
# Get the tracklist
resp = mopidy_rpc(host=host,
method='core.playlists.get_items',
params={"uri": playlist_id})
# Format tracklist
tracks = resp.json().get('result')
tracklist = list(map(lambda x: x['uri'], tracks))
# Clear playlist
method='core.tracklist.clear')
# Add Tracklist
method='core.tracklist.add',
params={"uris": tracklist})
# Get up ! (means mopidy play)
method='core.playback.play',
params={"tl_track": None})
It allow you to select a playlist with UI and a target.
It also create a service you can use in your automations.
My 2 cents.
P.
