It seems the only solution is to save what is currently playing, start the TTS, then start playing the previous title. I tried that workaround, but it’s a bit slow with TuneIn and will take about 15 seconds to buffer from HA, but 0 from direct Google input (hey google, start playing ) for no apparent reason. That’s 70% why I was wondering if there is any other way to make an announcement over currently playing music …
So my question is: Am I missing something, or is there really no way to easily continue playback?
I just use a separate PC speaker connected directly on the audio out of the HA server.
Independent on all the media players in the house and no hassle with automation’s to interrupt and activate media players. EASY
It was helpful, i spent my time to read your question and give you an viable option.
You choose not to do anything with it, and that is perfectly fine.
But saying it was not helpful works very demotivating for me to try help others. You could do something about this attitude…
This is on my list as well, although I’m using Chromecast Audios and a Plex server.
I don’t have a solution either, unfortunately. I did my research a few months ago and the common thread I saw was to save the state of your speakers as a scene, make the announcement, then restore the scene.
I tried that a few different ways without any luck. That said, I’m not very experienced with scenes, so I may not be doing it right. I paused my attempts for now. Hoping someone had the answer…
media_player.play_media offers control of the announce option (i.e. ability to set its value to true or false).
The announce feature isn’t exposed as a controllable option in tts.speak. It effectively behaves like media_player.play_media with the announce option set to true. Whether the announce feature actually works or not depends on the target speaker’s integration. For example, I know it works for Sonos.
I know this is an old topic, but this what I come up with and it works for my case. I'm new to this and I don't know if it will work for everyone's case.
