Playing error media and tts
Since a few days, Google Nest mini, won’t play local media or tts generated sentences through the speaker. The tts created mp3 file is saved in the tts directory. The Nest speaker card shows it’s playing, volume is up, but stops within seconds.
The log shows:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/media_source/local_source.py:57
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 7:29:41 (1 occurrences)
Last logged: 7:29:41
[1896120480] Invalid path.
  File "/usr/src/homeassistant/homeassistant/components/media_source/local_source.py", line 55, in async_parse_identifier
    raise_if_invalid_path(location)
  File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 46, in raise_if_invalid_path
    raise ValueError(f"{path} is not a safe path")
ValueError: Manus de papegaai ,Lekker aan het spelen en natuurlijk praten en praten en praten ... (1).mp3 is not a safe path
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 143, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1480, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1515, in _execute_service
    await handler.job.target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 206, in handle_service
    await self.hass.helpers.service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 649, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 692, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 686, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/cast/media_player.py", line 459, in async_play_media
    sourced_media = await media_source.async_resolve_media(self.hass, media_id)
  File "/usr/src/homeassistant/homeassistant/components/media_source/__init__.py", line 85, in async_resolve_media
    return await _get_media_item(hass, media_content_id).async_resolve()
  File "/usr/src/homeassistant/homeassistant/components/media_source/models.py", line 83, in async_resolve
    return await self.async_media_source().async_resolve_media(self)
  File "/usr/src/homeassistant/homeassistant/components/media_source/local_source.py", line 63, in async_resolve_media
    source_dir_id, location = self.async_parse_identifier(item)
  File "/usr/src/homeassistant/homeassistant/components/media_source/local_source.py", line 57, in async_parse_identifier
    raise Unresolvable("Invalid path.") from err
homeassistant.components.media_source.error.Unresolvable: Invalid path.
Can you show your config for playing one of the files?
I am not using any config. I’m using the Nest Speaker card on lovelace, well, I was until a few days ago…
Clicking the play sign opens my standard HA media folder and clicking on one of the MP3’s just did the trick…
Clicking on the 3 dots gives me the ability to type a sentence for tts
