Please add a sensor flag to prevent converting the unit
I’m working with environment calculations that need everything converted to metric. I’m in the States and still use the imperial units day to day. (I like to know how many rods my car gets to the hogs head for example.)
Rather than make one monster formula over and over for things like saturated mixing ratio, mixing ratio, C, g/Kg (water to air ratio) etc. I was trying to make template sensors for the individual values. I’d like to set their unit of measure without HA translating it so I can check my work and reuse the sensors.
As a work around I’m leaving the units off the sensor and putting it in the sensor name.
