Hi guys.
I can do a Mqtt publish through the Mosquitto broker integration with the below data.
topic
Zigbee2mqtt/hive_receiver/set
Payload (template allowed)
"system_mode":"emergency_heating",
"temperature_setpoint_hold_duration":"30",
"temperature_setpoint_hold":"1",
"occupied_heating_setpoint":"20"
And that runs and does what it should, So then i was trying to create a script based of that which i would use on tap_action on a custom button card.
I’ve since realised i can’t use the code as it is in the picture below because it needs to be a string but i can’t figure out how to convert that into a string for it to work i’ve been trying allsorts of variations from the documentation.
Any help appreciated
Script
