good day
I’m a beginner with sonoff, homeassistant and scripting
I know I will be funny for most, but I will still ask:
it is possible to set the automation trigger in the sense of:
if the date is from - to start automation every 5 minutes?
For example, help template?
So far, I can only think of very complicated ones:
Automation 1. - every 5 minutes - condition: date from - to; action run script
script: start automation 2.
I don’t know if it will help me, I need to repeat the automation every year. so I will enter only the day and month of the beginning and the day and month of the end …
- condition: template # Only between April 1 and September 30
value_template: "{{ 4 <= now().month <= 9 }}"
This automation is still going to trigger every 5 minutes all year though, wether it passes the condition and executes the actions or not. As I said earlier, this is not an efficient use of home assistant. If you explain what you are trying to do there may be a better way.
it will probably be necessary …
I’m not sure when the “Main heating switch” will turn on if the on-off of the second auxiliary switch is inadvertently switched on
