so my HA running on pi has this log something is causing it to Loop and over heat and crash leaving me a small window to try and fix it, i’ve done a new install and installed snapshot which has bought the problem over with it. can any one help with the problem. many thanks for you time
2020-10-21 17:57:00 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for shelly which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-10-21 17:57:00 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-10-21 17:57:12 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2020-10-21 17:57:21 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=23 from 2020-10-21 16:24:21.901974)
2020-10-21 17:57:43 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 1c2e1d2ddac73dc445941840ca3f64c84755c80168a9b515caabc70f57e74193 from 127.0.0.1
2020-10-21 17:57:44 ERROR (CoAP) [pyShelly] Error receive CoAP
File "/usr/local/lib/python3.8/site-packages/pyShelly/coap.py", line 182, in _loop
self._root.update_block(device_id, device_type,
File "/usr/local/lib/python3.8/site-packages/pyShelly/__init__.py", line 242, in update_block
block.update(data, ipaddr)
File "/usr/local/lib/python3.8/site-packages/pyShelly/block.py", line 92, in update
dev.update(data)
File "/usr/local/lib/python3.8/site-packages/pyShelly/switch.py", line 46, in update
self._update(state > 0, {'last_event' : self.last_event,
TypeError: '>' not supported between instances of 'NoneType' and 'int'
dev.update(data)
File "/usr/local/lib/python3.8/site-packages/pyShelly/relay.py", line 53, in update
self.info_values[INFO_VALUE_SWITCH] = switch_state > 0
dev.update(data)
dev.update(data)
dev.update(data)
2020-10-21 17:57:45 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:57:46 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:57:49 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:57:51 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:57:52 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:57:59 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:58:01 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:58:03 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:58:05 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:58:07 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
dev.update(data)
2020-10-21 17:58:09 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:58:11 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:58:13 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:58:15 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:58:16 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:58:17 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:58:19 ERROR (CoAP) [pyShelly] Error receive CoAP
dev.update(data)
2020-10-21 17:58:20 ERROR (SyncWorker_34) [bimmer_connected.account] Authentication failed. Maybe your password is invalid?
2020-10-21 17:58:20 ERROR (SyncWorker_34) [bimmer_connected.account] ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 670, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 426, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 421, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.8/http/client.py", line 1347, in getresponse
response.begin()
File "/usr/local/lib/python3.8/http/client.py", line 307, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.8/http/client.py", line 276, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 726, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 403, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.8/site-packages/urllib3/packages/six.py", line 734, in reraise
raise value.with_traceback(tb)
response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
