Please help all my automations are down
Logger: homeassistant.setup
Source: components/device_automation/init.py:112
First occurred: 20:44:28 (1 occurrences)
Last logged: 20:44:28
Error during setup of component automation
File “/usr/src/homeassistant/homeassistant/components/device_automation/init.py”, line 109, in async_get_device_automation_platform
integration = await async_get_integration_with_requirements(hass, domain)
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 58, in async_get_integration_with_requirements
integration = await async_get_integration(hass, domain)
File “/usr/src/homeassistant/homeassistant/loader.py”, line 570, in async_get_integration
integration = await _async_get_integration(hass, domain)
File “/usr/src/homeassistant/homeassistant/loader.py”, line 595, in _async_get_integration
raise IntegrationNotFound(domain)
homeassistant.loader.IntegrationNotFound: Integration ‘’ not found.
File “/usr/src/homeassistant/homeassistant/setup.py”, line 254, in _async_setup_component
result = await task
File “/usr/src/homeassistant/homeassistant/components/automation/init.py”, line 237, in async_setup
if not await _async_process_config(hass, config, component):
File “/usr/src/homeassistant/homeassistant/components/automation/init.py”, line 646, in _async_process_config
await async_validate_config_item(hass, raw_config),
File “/usr/src/homeassistant/homeassistant/components/automation/config.py”, line 86, in async_validate_config_item
config[CONF_ACTION] = await script.async_validate_actions_config(
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 241, in async_validate_actions_config
return await asyncio.gather(
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 288, in async_validate_action_config
choose_conf[CONF_SEQUENCE] = await async_validate_actions_config(
File “/usr/src/homeassistant/homeassistant/helpers/script.py”, line 256, in async_validate_action_config
platform = await device_automation.async_get_device_automation_platform(
File “/usr/src/homeassistant/homeassistant/components/device_automation/init.py”, line 112, in async_get_device_automation_platform
raise InvalidDeviceAutomationConfig(
homeassistant.components.device_automation.exceptions.InvalidDeviceAutomationConfig: Integration ‘’ not found
People will want a lot more information about what you’re trying to achieve and how you’re doing it.
no automations tab in settings
is now fixed
last automation has a error
