Please help: automation for IKEA TRADFRI remote control (E1524/E1810)
EDIT:
I created a much smoother and better solution for this problem. Check the following post to now more about it.
Hi @bartplessers,
I have been working on these recently. I have the same Ikea controller and I wanted a smooth solution for this. I found this post where the same is done but with a Xiomi controller: Finally - a cheap WIRELESS switch that dims! Xiaomi Switch Gen1. I started adapting it from the solution found on this post, but I have changed some things. The main thing I changed was to create a python script to dim up/down smoothly.
I created a package for it:
automation:
  ## Toggle the light
  - id: ikea_controller_toggle
    alias: Ikea Controller - Toggle
      - platform: state
        entity_id: sensor.YOURCONTROLLER_action
        to: "toggle"
      - service: light.toggle
          entity_id: light.YOURLIGHT
  ## Dim up/down and warm up/down with clicks
  - id: ikea_controller_dim_up
    alias: Ikea controller dim up
      platform: state
      to: brightness_up_click
      data_template:
        brightness: "{{ state_attr('light.YOURLIGHT', 'brightness') + 50 | int }}"
      service: light.turn_on
  - id: ikea_controller_dim_down
    alias: Ikea controller dim down
      platform: state
      to: brightness_down_click
      data_template:
        brightness: "{{ [state_attr('light.YOURLIGHT', 'brightness') - 50, 1] | max }}"
  - id: ikea_controller_warm_up
    alias: Ikea controller warm up
      platform: state
      to: arrow_right_click
      data_template:
        color_temp: "{{ state_attr('light.YOURLIGHT', 'color_temp') + 75 }}"
  - id: ikea_controller_warm_down
    alias: Ikea controller warm down
      platform: state
      to: arrow_left_click
      data_template:
        color_temp: "{{ state_attr('light.YOURLIGHT', 'color_temp') - 75 }}"
  ## Dim up/down with long press
  - id: ikea_controller_brighten_on
    alias: Ikea Controller - Brighten on
      - platform: state
        to: brightness_up_hold
      - condition: state
        state: "on"
        entity_id: input_boolean.light_brightness
      - service: python_script.change_attribute_light_smoothly
          light_id: light.YOURLIGHT
          input_boolean: input_boolean.light_brightness
          delta: 20
  - id: ikea_controller_dim_on
    alias: Ikea Controller - Dim on
      - platform: state
        to: brightness_down_hold
      - condition: state
        state: "on"
          delta: -20
  - id: ikea_controller_brighten_dim_off
    alias: Ikea Controller - Brighten/Dim off
    initial_state: "on"
      - platform: state
        to: brightness_up_release
      - platform: state
        to: brightness_down_release
      condition: and
      conditions:
        - condition: state
          state: "on"
        - condition: state
          state: "on"
  ## Warm up/down with long press
  - id: ikea_controller_warm_on
    alias: Ikea Controller - Warm on
      - platform: state
        to: arrow_right_hold
      - condition: state
        state: "on"
        entity_id: input_boolean.light_color_temp
          input_boolean: input_boolean.light_color_temp
          light_attribute: color_temp
          delta: 40
  - id: ikea_controller_col_on
    alias: Ikea Controller - Cold on
      - platform: state
        to: arrow_left_hold
      - condition: state
        state: "on"
          delta: -40
  - id: ikea_controller_warm_cold_off
    alias: Ikea Controller - Warm/Cold off
    initial_state: "on"
      - platform: state
        to: arrow_left_release
      - platform: state
        to: arrow_right_release
      condition: and
      conditions:
        - condition: state
          state: "on"
        - condition: state
          state: "on"
# Inputs to control the dim up/down and warm up/down smoothly
input_boolean:
  light_brightness:
    name: Light brigthness
    initial: off
  light_color_temp:
    name: Light color temperature
    initial: off
You will need to change:
  • YOURLIGHT: Your light entity
  • YOURCONTROLLER: Your controller
You can add this file on packages folder and on the configuration.yaml:
homeassistant:
  packages: !include_dir_named packages
python_script:
Then, you will need to add the following script (change_attribute_light_smoothly.py) inside /config/python_scripts:
input_boolean = data.get("input_boolean")
light_id = data.get("light_id")
delta = data.get("delta")
attribute_id = data.get("light_attribute", "brightness")
delay = data.get("delay", 350)
attribute_mapping = {
    "brightness": {"min": 1, "max": 255},
    "color_temp": {"min": 153, "max": 500},
exit_service = False
while True:
    switch_input = hass.states.get(input_boolean).state
    if switch_input == "off":
        break
    light = hass.states.get(light_id)
    attr_value = light.attributes[attribute_id]
    attr_value = attr_value + delta
    if attr_value < attribute_mapping[attribute_id]["min"]:
        attr_value = attribute_mapping[attribute_id]["min"]
        exit_service = True
    elif attr_value > attribute_mapping[attribute_id]["max"]:
        attr_value = attribute_mapping[attribute_id]["max"]
        exit_service = True
    service_data = {"entity_id": light_id, attribute_id: attr_value}
    logger.warning(f"Service data: {service_data}")
    hass.services.call("light", "turn_on", service_data)
    if exit_service:
        break
    time.sleep(delay / 1000)
I hope this helps you with your needs.
