Hi, I’m a total newbie to the home assistant, but really liked the whole idea, after aquering all of the components I installed hass.io to SD card, configured the wifi, but i can’t open the ip address. And I’m pretty confused where’s my problem is it the router or the raspberry pi 3 b+ (btw using Huawei B315s-22 router)
Can you see the pi showing up in your router as the specified IP address?
Can you ping the IP address?
Can you connect a monitor? See if things are starting? There may be output that is helpful.
I can see the ip that is named hassio but can’t connect to it , conected monitor shows a lot of text(added pic)
You said you cannot connect to it, can you ping it? Lets see if its actually connected.
Yes the ping was successful
Are you using http://ipofyourpi:8123 as the address?
8123 is the port the web part of HA runs on, if you don’t specify it, you won’t connect.
Yes, I’m using that address
Still I can’t get it to be working, any help?
