Please help fix blueprint
Hi everybody,
I am trying to create a blueprint, but keep getting this error Message malformed: template value should be a string for dictionary value @ data['action'][0]['then'][0]['data']; I have tried re-formatting the action part of my yaml file, but no matter what I do, the error persists. I have been restarting Home Assistant after each attempted fix, but nothing makes a difference…
This is how the blueprint currently looks:
blueprint:
  name: 'Heizungen Zeitsteuerung'
  description: ''
  domain: automation
  input:
    heizung:
      description: ''
      selector:
        entity:
          domain: climate
    fenster:
      description: ''
      selector:
        entity:
          domain: binary_sensor
          device_class: window
    zeit_00:
      description: 'input_datetime.*'
      selector:
        entity:
          domain: input_datetime
    zeit_01:
      selector:
        entity:
    zeit_02:
      selector:
        entity:
    zeit_03:
      selector:
        entity:
    zeit_04:
      selector:
        entity:
    zeit_05:
      selector:
        entity:
    temperatur_00:
      selector:
        entity:
    temperatur_01:
      selector:
        entity:
    temperatur_02:
      selector:
        entity:
    temperatur_03:
      selector:
        entity:
    temperatur_04:
      selector:
        entity:
    temperatur_05:
      selector:
        entity:
  - platform: state
    entity_id: !input zeit_00
  - platform: state
    entity_id: !input zeit_01
  - platform: state
    entity_id: !input zeit_02
  - platform: state
    entity_id: !input zeit_03
  - platform: state
    entity_id: !input zeit_04
  - platform: state
    entity_id: !input zeit_05
  - if:
      condition: trigger
    then:
      service: climate.set_temperature
        temperature: '{{ states(!input temperatur_00) | float }}'
        entity_id: !input heizung
  - if:
      condition: trigger
    then:
        temperature: '{{ states(!input temperatur_01) | float }}'
  - if:
      condition: trigger
    then:
        temperature: '{{ states(!input temperatur_02) | float }}'
  - if:
      condition: trigger
    then:
        temperature: '{{ states(!input temperatur_03) | float }}'
  - if:
      condition: trigger
    then:
        temperature: '{{ states(!input temperatur_04) | float }}'
  - if:
      condition: trigger
    then:
        temperature: '{{ states(!input temperatur_05) | float }}'
Basically, I have input_datetime.unten_arbeitszimmer_heizung_00 to input_datetime.unten_arbeitszimmer_heizung_05 per room (the unten_arbeitszimmer part changes for each room there is). These are the times at which to trigger the automation, then there are input_number.unten_arbeitszimmer_heizung_00 to 05, which are the wanted temperatures at those times.
The window entity is currently not yet implemented, this is for later…
Originally, the part looked like this
  - if:
      condition: trigger
    then:
      - service: climate.set_temperature
But the produces the same error as the current code from above.
Thank you in advance for your help :slight_smile:
