PLEASE HELP, HA broke after backup restore and can't go back
Hi guys. A couple of days ago I updated, didn’t like IT, applied a backup restore and then everything broke. When installing the backup HA won’t boot, I’m not able to acces throgh the web browser. I narrowed down the problem to a custom component. If I remove it, it works. How can I delete a custom component from a backup prior to installing it? modifying the yaml would do the trick too
any help will be appreciated
Custom component can be found config folder >> custom_components folder
You can probably remove from there.
