When I run the below command on Windows 10 (after installing the latest Python version 3.7.7) I can’t get passed the installation error below. It looks like it’s a Python-related error
Things i’ve tried (everything bu tthe kitchen sink):
-Upgrading to the latest Python version 3.7.7
-Deleted the config directory for HA and reinstalled HA
-Installed “Build Tools for Visual Studio”
-Upgraded PIP to the latest version
-pip3 install homeassistant --no-cache-dir
-pip3 uninstall wheel …pip3 install wheel
-pip install pip --upgrade
-pip install setuptools --upgrade
The installation starts output red text error message; and, halts the installation:
Installing collected packages: ciso8601, homeassistant
Running setup.py install for ciso8601 ... error
ERROR: Command errored out with exit status 1:
command: 'c:\users\michael\appdata\local\programs\python\python37\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\Michael\\AppData\\Local\\Temp\\pip-install-mo203h2c\\ciso8601\\setup.py'"'"'; __file__='"'"'C:\\Users\\Michael\\AppData\\Local\\Temp\\pip-install-mo203h2c\\ciso8601\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\Michael\AppData\Local\Temp\pip-record-5_mq23wj\install-record.txt' --single-version-externally-managed --compile --install-headers 'c:\users\michael\appdata\local\programs\python\python37\Include\ciso8601'
cwd: C:\Users\Michael\AppData\Local\Temp\pip-install-mo203h2c\ciso8601\
Complete output (12 lines):
running install
running build
running build_py
package init file 'ciso8601\__init__.py' not found (or not a regular file)
creating build
creating build\lib.win-amd64-3.7
creating build\lib.win-amd64-3.7\ciso8601
copying ciso8601\__init__.pyi -> build\lib.win-amd64-3.7\ciso8601
copying ciso8601\py.typed -> build\lib.win-amd64-3.7\ciso8601
running build_ext
building 'ciso8601' extension
error: Microsoft Visual C++ 14.0 is required. Get it with "Build Tools for Visual Studio": https://visualstudio.microsoft.com/downloads/
ERROR: Command errored out with exit status 1: 'c:\users\michael\appdata\local\programs\python\python37\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\Michael\\AppData\\Local\\Temp\\pip-install-mo203h2c\\ciso8601\\setup.py'"'"'; __file__='"'"'C:\\Users\\Michael\\AppData\\Local\\Temp\\pip-install-mo203h2c\\ciso8601\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\Michael\AppData\Local\Temp\pip-record-5_mq23wj\install-record.txt' --single-version-externally-managed --compile --install-headers 'c:\users\michael\appdata\local\programs\python\python37\Include\ciso8601' Check the logs for full command output.
I would really appreciate any help to get this past these error messages. I dont have any other issues related to Python on mysetup.
