Today l purchased this dimmer module and was able to successfully pair it with HA and was able to perform basic automation functions e.g. switching the light on and off, l was able to manually adjust dimming of the lights via the Dashboard.
The issue is that I am unable to get the dimmer module to either gradually increase/decrease the brightness a over period of time using the Transition parameter via the Call Service under the Developer Tools
When lâve clicked âcall serviceâ for the above the light just switches on instantly to 100% brightness with NO fade-in effect. It appears the Transition parameter does not have any effect.
According to zigbee2mqtt it has an optional âhardâ transition time which can be overridden in mqtt/ha. Of course that doesnât help in ZHA, but may give you an idea.
EDIT: what does supported_features: report (see states panel in dev tools).
Iâve installed zigbee2mqtt added the devices, unfortunately, the same issue, the Transition setting has no effect i.e. the light turns on instantly at the brightness setting that I have set.
I run the above using a simple Call Service Light:Turn on and have adjusted the settings i.e. âTransitionâ and âBrightness valueâ
I was able to get the transition effect working in Hubitat using the standard Hubitat settings but the same does not work in HA.
What l have done is to add a Hubitat integration in HA and are using HA to control the light dimmer via Hubitat, this is not ideal
I might ditch the light dimmer and replace with Ikea zigee smart globes instead (more expensive option thoughâŚ)
