I just wanted to update my Zigbee coordinator to a new firmware. I wanted to confirm the hardware, to make sure I use the correct firmware (since there is also the Dongle-E with Silicon Labs chip).
My order from Amazon states this in the description:
SONOFF Zigbee 3.0 USB Dongle Plus,2 Stück ZBDongle-P TI CC2652P + CP2102(N) Zigbee USB-Stick für ZHA in Home Assistant or Zigbee2MQTT,Open HAB etc.
So a TI chipset. This is what I had remembered and, in fact, I flashed the second USB-stick (the order contained two) with the router firmware from TI.
But I also checked the reported hardware in Home Assistant (i.e. under http://homeassistant.local:8123/config/hardware). And there it outputs ID_SERIAL: Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001
, which indicates a chipset Silicon Labs (which would be a Dongle-E version).
So what is going on here?! (Given everything, I am certain that this is in fact a ZBDongle-P with TI chipset…)
Here is the full output:
BUSNUM: '001'
DEVNAME: /dev/bus/usb/001/003
DEVNUM: '003'
DEVPATH: >-
/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_FOR_SEAT: usb-platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_3
ID_MODEL: Sonoff_Zigbee_3.0_USB_Dongle_Plus
ID_MODEL_ENC: Sonoff\x20Zigbee\x203.0\x20USB\x20Dongle\x20Plus
ID_MODEL_ID: ea60
ID_PATH: platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3
ID_PATH_TAG: platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_3
ID_PATH_WITH_USB_REVISION: platform-fd500000.pcie-pci-0000:01:00.0-usbv2-0:1.3
ID_REVISION: '0100'
ID_SERIAL_SHORT: '0001'
ID_USB_INTERFACES: ':ff0000:'
ID_USB_MODEL: Sonoff_Zigbee_3.0_USB_Dongle_Plus
ID_USB_MODEL_ENC: Sonoff\x20Zigbee\x203.0\x20USB\x20Dongle\x20Plus
ID_USB_MODEL_ID: ea60
ID_USB_REVISION: '0100'
ID_USB_SERIAL: Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001
ID_USB_SERIAL_SHORT: '0001'
ID_USB_VENDOR: Silicon_Labs
ID_USB_VENDOR_ENC: Silicon\x20Labs
ID_USB_VENDOR_ID: 10c4
ID_VENDOR: Silicon_Labs
ID_VENDOR_ENC: Silicon\x20Labs
ID_VENDOR_ID: 10c4
MAJOR: '189'
MINOR: '2'
PRODUCT: 10c4/ea60/100
SUBSYSTEM: usb
TAGS: ':seat:'
TYPE: 0/0/0
USEC_INITIALIZED: '4072146'
