Please help me write eshome code
I am writing this post because I do not understand something.
I am in the process of making a panel that is supposed to display the status of some entities from my Homeassistant and it works for me.
The problem arose when I want to control the integrated Gree air conditioning. My panel is based on esp32 and ili9341 display and the software is esphome.
According to the eshome documentation, in order to be able to control the air conditioning device, you need to create a climate component. After writing a platform with the name taken from homeassistant, I get the error “Platform not found: ‘climate.c69a3408’.”
I use the same name to create a sensor that displays the set temperature and it works fine.
Blockquote
#Import external klima salon
- platform: homeassistant
entity_id: climate.c69a3408
attribute: temperature
internal: true
Please explain what to do so that I can set my air conditioning with my esp.
I’m sorry for my English
There is no way to import Home Assistant climate entities into ESPHome.
You can import sensors, binary sensors, text sensors and time from Home Assistant, but not climate devices.
These are the only ESPHome climate components available: ESPHome — ESPHome
Thank you for your answer !
So there is no way to change the value or operating mode of my climate remotely using esphome?
I use TTGO lcd. I only set the temperature. I get the temperatures from the homeassistant and use the buttons to call the service homeassistant. List of call services: Climate - Home Assistant Please excuse my English :slight_smile:
    entity_id: climate.obyvak
    attribute: current_temperature
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      inverted: true
      mode:
        input: true
        pullup: true
    on_press:
      - homeassistant.service:
          service: climate.set_temperature
            temperature: !lambda |-
                  return id(set_temperature).state - 0.5;
      - component.update: display_lcd
  - platform: gpio
    pin:
      number: GPIO35
      inverted: true
    on_press:
                  return id(set_temperature).state + 0.5;
Yes, you can use any home assistant service. Native API Component — ESPHome
Thank you friends. You helped me fill my knowledge gaps.
