Hello, I am a networking newbie and I haven’t been able to switch my Raspberry Pi 3’s IP address to something that my router can detect.
Hass.io is working via hassio.local:8123 and I’ve got SAMBA and Putty working. My problem is that my router itself cannot detect my Pi’s local IP address which is 192.168.1.71 according to my Fing app.
When I do ifconfig in Putty I see:
inet addr:172.30.33.0 Bcast:0.0.0.0 Mask:255.255.254.0
How do I change the IP to 192.168.1.71 and the subnet mask to 255.255.255.0 ? I believe that is what I need to do in order to have my router detect the Pi itself so that I can set up port forwarding rules.
I had/have Home Assistant running on a Windows 10 PC smoothly and only yesterday did I gett this Pi 3 set up and working with Hass.io. Now I would like to get this Hassio setup nicely so I can stop using the Windows version altogether but this IP address thing has me really stuck.
I’ve tried editing the /etc/dhcpcd.conf which was blank to:
interface eth0
static ip_address=192.168.1.71/24
I’ve also tried editing the resin connection file on my sd card to:
Thanks. I’m part way there. I did a fresh install of Hass.io again and have it detected in my router now. I also have it assigned in the DCHP list.
What I can’t understand now is how to access Home Assistant remotely. With my WIndows 10 setup of HA I could use my external ip address:8123 to load HA on my other devices. Now I use ifconfig to find the ip address on the pi3 but the page never loads when I try ipaddress:8123 on my other devices. Any ideas where I am going wrong there?
I notice when I do ifconfig on the pi3 that it lists the mask as: 255.255.254…0 and all my other devices on my network are 255.255.255.0 but I don’t know how to change it to match. and i’m not sure if that is my problem or not.
Probably a huge noob question but should all of my devices on my network have the same external ip address? if so, my pi3 address is different than my old windows 10 HA setup computer had for it’s external ip address.
Thank you very much for mentioning that. Setting up a reverse proxy was going to be my next step I think I was just trying to identify an external ip address I could use with the Pi3. Do I have that option?
If I follow the tutorials to set up duckdns and letsencrypt will that solve my problem as far as security?
I bought a webhosting package and domain name the other day and I would like to make something like mysite.com/ha point to Hassio and mysite.com/plex point to my plex server. Do you know of any good tutorials showing how to do that? I’ve searched a lot but maybe am not using the right key words.
Thank you I am trying to figure out where to put that config. I installed the nginx addition for hass.io but when I use samba to explore files I just see my Home Assistant config files no new folder for nginx.
I did get duckdns and lets encrypt working so I have it it working with: mydomain.duckdns.com
I would like it to just be mydomain.com to work with my plex and I assume the config above would let me do that but would I need to do anything on my webhosted domain itself? Or is this all on my pi3 side?
and ever since I got the duckdns and lets encrypt working I can no longer reach my HA in my browser with localip:8123 I can now only use the mydomain.duckdns.org
You need to update your domain dns a record to point to your isp assigned IP address.
If your isp assigned ip address is dynamic (most are) then you need to get your ddns service to update the dns.
I use cloud flare to manage my dns and dnsomatic as a ddns provider. Dnsomatic is cool as it allows you to update multiple sites in one call - eg update cloudflare and duckdns and afraid.org.
So for me my ddns client runs on my (ubiquiti) router.
When my isp ip changes, the router updates dnsomatic which updates cloudflare with multiple sub domains eg homeassistant.mydomain.com
Regarding not being able to access locally. This is because your router does not support hairpin NAT, or has it disabled ,
You need to enable hairpin NAT - e.g.:
