Please help test temperature widget
I have found that the temperature widget shows the correct temperature digitally but not graphically. When the containing dashboard is first compiled/loaded, the indicator bar sits at the minimum temperature set for the widget. If the dashboard is displayed for long enough, it will update the indicator bar to the correct temperature, but lose it if I navigate away from that page.
I have made a minor modification to the javascript code for the widget which I’ve been using for a couple of years. I decided to share it with the world, but I need to get some other users testing it. I would provide the widget code as a (tiny) zip file, and you would install it as a custom widget. I will provide instructions.
Very easy with no permanent consequences - just delete the custom widget and you’re back to the library widget. Please respond here if you are willing to test this widget. Here’s what it looks like with the indicator bar at the correct value.
TemperatureWidget
I would be glad to test. Please PM me and we can set it up.
