Please help - When I update from 11.2 to 12.2 I cannot access my HA locally - Running core and OS on HA Blue
Hi all. I have been having such a problem here so any help is appreciated. I’ve tried this a few times and have to keep restoring back to 11, as I’m not sure what the issue is.
when I update to 12, I cannot access my instance locally. I did at one point somehow get it to work, but then I couldn’t access remotely through Nabu Casa, so rebooted and now I’m back at the same spot. I get this error: Failed to create HTTP server at port 8123: [Errno 98] error while attempting to bind on address (‘0.0.0.0’, 8123): [errno 98] address in use. I have no idea what is listening on that port.
Further info:
using a static ip
I can ping the box
I can access through nabu casa
I can access with the ip address with :4357
I have disable ipv6 and made ipv4 static
I’ve rebooted my router
automations seem to work but not Node Red, (shows connecting on devices)
running z2m as well if that matters.
any help on how to fix this is very much appreciated. I have full backups if that matters and can log in through Nabu Casa.
if it helps anyone, I disabled Alexa media player and was able to update.
