Please help with configuring torque
Hello I cannot get torque to work. I have following questions, can someone answer them please?
My HA instance is http (not https) running on DMZ behind router. It is accessible from internet, I use mqtt integration from internet well.
  1. if I use http, do I need to set in torque app server as https://<ip address>:443/api/torque ? Seems like I do, when I used http I was getting authorization error and could not set bearer token
  2. is there a way how to check in torque app if connection is successfull?
  3. in HA, where can I find the sensor, or how it is called? Can I find it by “torque” text?
Thanks, Jan
