Dubak
(Lion®)
December 27, 2021, 9:14am
1
I ask very nicely and also urgently for help with the aroma diffuser Christmas gift
My Aroma diffuser requires the following ventilator configuration
fan:
- platform: mqtt
icon: "mdi:smoke"
state_topic: "stat/aroma_difuzer/RESULT"
state_value_template: "{% if value_json.POWER1 is defined %}{{ value_json.POWER1 }}{% endif%}"
command_topic: "cmnd/aroma_difuzer/POWER1"
preset_modes:
- "2h timer"
- "4h timer"
- "timer off"
preset_mode_state_topic: "stat/aroma_difuzer/timer"
preset_mode_command_topic: "cmnd/aroma_difuzer/tuyaenum2"
preset_mode_command_template: >-
{% if value == "2h timer" %}
{{ 0 }}
{% elif value == "4h timer" %}
{{ 1 }}
{% else %}
{{ 2 }}
{% endif %}
percentage_state_topic: "stat/aroma_difuzer/fanmode"
percentage_value_template: >-
{% if value == "low" %}
{{ 1 }}
{% elif value == "medium" %}
{{ 2 }}
{% elif value == "high" %}
{{ 3 }}
{% else %}
{{ 0 }}
{% endif %}
percentage_command_topic: "cmnd/aroma_difuzer/event"
percentage_command_template: >-
{% if value == 1 %}
{{ 'fanmode=1' }}
{% elif value == 2 %}
{{ 'fanmode=0' }}
{% elif value == 3 %}
{{ 'fanmode=2' }}
{% else %}
{{ 'fanmode=-1' }}
{% endif %}
speed_range_max: 3
availability_topic: "tele/aroma_difuzer/LWT"
payload_available: "Online"
payload_not_available: "Offline"
unique_id: "fan-diffuser"
select:
- platform: mqtt
name: "Diffuser Color Mode"
state_topic: "stat/aroma_difuzer/colormode"
options:
- "solid"
- "cycle"
availability:
- payload_available: "Online"
unique_id: "select-livingroom-diffueser-color-mode"
binary_sensor:
- platform: mqtt
state_topic: "stat/aroma_difuzer/error"
value_template: "{{ 'ON' if value != '0X00' else 'OFF' }}"
device_class: problem
unique_id: "binary-diffueser-error"
The lovelace card that I want to control the fan again requires this code :
fan:
- platform: mqtt
command_topic: "cmnd/aroma_difuzer/FanSpeed"
speed_command_topic: "cmnd/aroma_difuzer/FanSpeed"
speed_state_topic: "stat/aroma_difuzer/RESULT
state_value_template: >
{% if value_json.FanSpeed is defined %}
{% if value_json.FanSpeed == 0 -%}0{%- elif value_json.FanSpeed > 0 -%}4{%- endif %}
{% else %}
{% if states.fan.master_bedroom_fan.state == 'off' -%}0{%- elif states.fan.master_bedroom_fan.state == 'on' -%}4{%- endif %}
{% endif %}
speed_value_template: "{{ value_json.FanSpeed }}"
availability_topic: tele/aroma_difuzer/LWT
payload_off: "0"
payload_on: "4"
payload_low_speed: "1"
payload_medium_speed: "2"
payload_high_speed: "3"
payload_available: Online
payload_not_available: Offline
speeds:
- "off"
- low
- medium
- high
Respectively, I need using card:
Control from lovelace this aroma diffuser :
Thank you in advance for your amazing strength of help.
finity
December 27, 2021, 3:07pm
2
don’t use the fan-control-entity-row plugin.
use either the fan-percent-button-row or fan-preset-button-row available from the same github user (me )
the fan-control-entity-row is only for previous versions of HA that used fan speeds and not percentages/presets.
Dubak
(Lion®)
December 28, 2021, 4:38am
3
Thank you.
That’s good.
But my aroma diffuser doesn’t even listen to this card (doesn’t accept)
finity
December 28, 2021, 4:40am
4
I have no idea what that means.
is the diffuser entity a “fan.xxx”?
and does it use percent speeds or preset modes to control it when you open it up in the frontend?
Dubak
(Lion®)
December 28, 2021, 5:19am
5
Yes. It’s a fan domain.
Your questions are best answered by the fan configuration:
fan:
- platform: mqtt
icon: "mdi:smoke"
state_topic: "stat/%topic%/RESULT"
command_topic: "cmnd/%topic%/POWER1"
preset_modes:
- "2h timer"
- "4h timer"
- "timer off"
preset_mode_state_topic: "stat/%topic%/timer"
preset_mode_command_topic: "cmnd/%topic%/tuyaenum2"
{{ 0 }}
{{ 1 }}
{% else %}
{{ 2 }}
{% endif %}
percentage_state_topic: "stat/%topic%/fanmode"
{{ 1 }}
{{ 2 }}
{{ 3 }}
{% else %}
{{ 0 }}
{% endif %}
percentage_command_topic: "cmnd/%topic%/event"
{% if value == 1 %}
{{ 'fanmode=1' }}
{{ 'fanmode=0' }}
{{ 'fanmode=2' }}
{% else %}
{{ 'fanmode=-1' }}
{% endif %}
speed_range_max: 3
availability_topic: "tele/%topic%/LWT"
select:
- platform: mqtt
state_topic: "stat/%topic%/colormode"
options:
- "solid"
- "cycle"
availability:
binary_sensor:
- platform: mqtt
state_topic: "stat/%topic%/error"
payload_not_avail: "Offline"
finity
December 28, 2021, 5:34am
6
I saw that already. And it looks like you can use either percents or presets.
but it still doesn’t answer:
I don’t know what you mean by this?
Dubak
(Lion®)
December 28, 2021, 7:30am
7
I can already change the intensity level (speed) and presets (timers).
Speed is enough for me three values: 33 - 66 - 100. So I’d appreciate the buttons rather than the slider.
I also wanted to change the color of the active preset buttons - this is not possible.
I don’t know why I have so many problems, probably due to the unconventional Fan configuration
Thank you.
finity
December 28, 2021, 7:40am
8
you still haven’t answered this question yet.
Dubak
(Lion®)
December 28, 2021, 7:52am
9
I don’t understand what kind of answer you’re expecting…
Dubak
(Lion®)
December 28, 2021, 8:03am
10
type: custom:fan-percent-button-row
entity: fan.difuzer
reverseButtons: false
customTheme: true
customSetpoints: true
lowPercentage: '33'
medPercentage: '66'
hiPercentage: '100'
isOnLowColor: '#CCFF99'
isOnMedColor: '#888888'
isOnHiColor: '#222222'
buttonInactiveColor: '#202020'
isOffColor: red
customLowText: Slabě
customMedText: Středně
customHiText: Silně
customOffText: 'OFF'
width: 50px
height: 46px
finity
December 28, 2021, 8:41am
11
The answer I was expecting was demonstrated in the video. Thanks for that.
Could you look in the “states” section of the developers tools for that fan and tell me what the “speed” & “percentage” attributes are when you change the speeds with the slider (not the card)?
like this:
What I think is possibly happening is that your percentages are being set to 0,1,2,3 in the config and the built-in slider uses those numbers but the card config is using 33,66,100 for the settings. And since the two don’t match it can’t work.
finity
December 28, 2021, 9:17am
13
What does it look like when it is actually on each of the three speeds?
Dubak
(Lion®)
December 28, 2021, 9:58am
14
That’s the mystery. It only changes. On - Off.
There are two hw buttons on the device, from the home assistant I am able to control the mqtt device exactly the same. But when I want to use some services from HA as a fun.xxx turn_on (turn-off). The device does not respond to these commands at all.
finity
December 28, 2021, 10:03am
15
TBH, I have zero experience with any tuya fans so I’m not sure how the integration interacts with HA and the fan integration.
Unfortunately until you get the fan control worked out to work with the HA fan services then none of my plugins will work for you since my plugins just use the built-in services with a different UI.
Dubak
(Lion®)
December 28, 2021, 10:07am
16
Thank you for your time and patience.
I’m going to look for what else I need to do…
finity
December 28, 2021, 10:10am
17
You’re welcome. Sorry I couldn’t help any more.
Dubak
(Lion®)
December 29, 2021, 10:17am
18
succeeded
solved - works as a percentage
Thanks.
Dubak
(Lion®)
December 29, 2021, 10:35am
19
I would also like to ask:
I have set up
preset_modes:
- "2h timer"
- "4h timer"
- "timer off"
a percentage state topic
{{ 1 }}
{{ 2 }}
{{ 3 }}
{% else %}
{{ 0 }}
{% endif %}
and speed shows me the preset mode - see picture
is that correct or is there still a mistake?
finity
December 29, 2021, 11:33am
20
Again, I’m not sure how the presets are supposed to look in the interim between the speed list and the percentages.
It seems they are just adding everything to the speed list.
But if it’s working I wouldn’t mess with it any more if it was me.
