Please help with intermittent notify iOS error
I’m running Hass.io 0.67.1 on an RPi 3B. I have an automation which, when a motion sensor detects motion, creates a persistent notification, sends a notification to my iPhone, and then the automation turns itself off for 10 minutes. It looks like this:
- alias: Notify xxx iPhone with delay
  initial_state: "on"
    platform: state
    entity_id: sensor.motion
    to: 'motion detected'
  condition:
    condition: time
    before: '23:00:00'
    after: '10:00:00'
    - service: persistent_notification.create
        message: "Motion has been detected"
        title: "Motion Sensor Activity"
    - service: notify.ios_xxxs_iphone
        message: 'Motion detected'
          push:
            sound: "US-EN-Alexa-Motion-Detected-Generic.wav"
    - service: automation.turn_off
      entity_id: automation.notify_xxx_iphone_with_delay
    - delay:
        minutes: 10
    - service: automation.turn_on
The automation itself always works - it triggers properly, the persistent notification always happens, and the automation turning on and off works properly. The iOS notification part is the problem. It often works, but sometimes it does not. I get the following errors in my log when it doesn’t work. Can anyone help me understand what might be causing this? I need the iOS notifications to be reliable. Thank you for any help you can provide.
2018-05-02 16:04:52 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall notify.ios_xxxs_iphone: message=<homeassistant.helpers.template.Template object at 0x70b76410>, data=push=sound=US-EN-Alexa-Motion-Detected-Generic.wav>
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
    (self.host, self.port), self.timeout, **extra_kw)
  File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 60, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/lib/python3.6/socket.py", line 745, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
    chunked=chunked)
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 346, in _make_request
    self._validate_conn(conn)
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 850, in _validate_conn
    conn.connect()
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 284, in connect
    conn = self._new_conn()
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 150, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7087a990>: Failed to establish a new connection: [Errno -3] Try again
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
    timeout=timeout
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='ios-push.home-assistant.io', port=443): Max retries exceeded with url: /push (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7087a990>: Failed to establish a new connection: [Errno -3] Try again',))
  File "/usr/lib/python3.6/site-packages/homeassistant/core.py", line 1002, in _event_to_service_call
    await service_handler.func(service_call)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/notify/__init__.py", line 137, in async_notify_message
    yield from notify_service.async_send_message(**kwargs)
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/lib/python3.6/site-packages/homeassistant/components/notify/ios.py", line 94, in send_message
    req = requests.post(PUSH_URL, json=data, timeout=10)
  File "/usr/lib/python3.6/site-packages/requests/api.py", line 112, in post
    return request('post', url, data=data, json=json, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/api.py", line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
    r = adapter.send(request, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 508, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='ios-push.home-assistant.io', port=443): Max retries exceeded with url: /push (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7087a990>: Failed to establish a new connection: [Errno -3] Try again',))
