Logger: homeassistant.setup
Source: setup.py:152
First occurred: 7:33:24 AM (3 occurrences)
Last logged: 7:33:58 AM
Unable to set up dependencies of logbook. Setup failed for dependencies: recorder
Unable to set up dependencies of history. Setup failed for dependencies: recorder
Unable to set up dependencies of default_config. Setup failed for dependencies: history, logbook
I have been using Maria DB for more than a year. I lost power and after that I am getting the warning. I reinstalled Maria DB and that didn’t fix it.
Version: '10.4.17-MariaDB' socket: '/run/mysqld/mysqld.sock' port: 3306 MariaDB Server
[10:23:17] INFO: Check data integrity and fix corruptions
mysql.column_stats OK
mysql.columns_priv OK
mysql.db OK
mysql.event OK
mysql.func OK
mysql.global_priv OK
mysql.gtid_slave_pos OK
mysql.help_category OK
mysql.help_keyword OK
mysql.help_relation OK
mysql.help_topic OK
mysql.index_stats OK
mysql.innodb_index_stats OK
mysql.innodb_table_stats OK
mysql.plugin OK
mysql.proc OK
mysql.procs_priv OK
mysql.proxies_priv OK
mysql.roles_mapping OK
mysql.servers OK
mysql.table_stats OK
mysql.tables_priv OK
mysql.time_zone OK
mysql.time_zone_leap_second OK
mysql.time_zone_name OK
mysql.time_zone_transition OK
mysql.time_zone_transition_type OK
mysql.transaction_registry OK
[10:23:17] INFO: Ensuring internal database upgrades are performed
This installation of MariaDB is already upgraded to 10.4.17-MariaDB, use --force if you still need to run mysql_upgrade
[10:23:18] INFO: Ensure databases exists
[10:23:18] INFO: Create database homeassistant_db
[10:23:18] INFO: Ensure users exists and are updated
[10:23:18] INFO: Update user hass_db_admin
[10:23:18] INFO: Init/Update rights
[10:23:19] INFO: Granting all privileges to hass_db_admin on homeassistant_db
[10:23:19] INFO: Successfully send service information to Home Assistant.
2021-06-09 10:24:43 22 [Warning] Access denied for user 'hass_db_admin'@'172.30.32.1' (using password: YES)
