Please, Help with MQTT Bridge with zendure
Sorry for my english :wink:
I have a small problem with the MQTT integration in bridge mode.
I want to add a new broker.
my first broker is for zigbee2mqtt ans work fine.
I add in the moskitto addon
logins: []
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
  active: true
  folder: mosquitto
debug: false
And 3 files in share folder like this
In zendure.conf
connection zendure-broker
address mqtt-eu.zen-iot.com:1883
remote_username 7csIB2c3
remote_password 0777F1895168481
remote_clientid 7csIB2c3
topic 7csIB2c3/# in
Only I don’t know where i find my information In a topic And I don’t know if it can connect to my zendure broker ?
Below The Mosquito broker logs in début mode.
[16:36:59] INFO: Starting NGINX for authentication handling...
[16:36:59] INFO: Starting mosquitto MQTT broker...
1730648219: Loading config file /share/mosquitto/acl.conf
1730648219: Loading config file /share/mosquitto/zendure.conf
2024-11-03 16:36:59: Warning: Mosquitto should not be run as root/administrator.
2024-11-03 16:36:59: mosquitto version 2.0.18 starting
2024-11-03 16:36:59: Config loaded from /etc/mosquitto/mosquitto.conf.
2024-11-03 16:36:59: Loading plugin: /usr/share/mosquitto/go-auth.so
s6-rc: info: service legacy-services successfully started
2024-11-03 16:36:59:  ├── Username/password checking enabled.
2024-11-03 16:36:59:  ├── TLS-PSK checking enabled.
2024-11-03 16:36:59:  └── Extended authentication not enabled.
time="2024-11-03T16:36:59+01:00" level=debug msg="got 2 users from passwords file"
time="2024-11-03T16:36:59+01:00" level=debug msg="got 0 lines from acl file"
time="2024-11-03T16:36:59+01:00" level=info msg="Backend registered: Files"
time="2024-11-03T16:36:59+01:00" level=debug msg="new hasher: pbkdf2"
time="2024-11-03T16:36:59+01:00" level=info msg="Backend registered: HTTP"
time="2024-11-03T16:36:59+01:00" level=info msg="registered acl checker: files"
time="2024-11-03T16:36:59+01:00" level=info msg="registered user checker: files"
time="2024-11-03T16:36:59+01:00" level=info msg="registered superuser checker: files"
time="2024-11-03T16:36:59+01:00" level=info msg="registered acl checker: http"
time="2024-11-03T16:36:59+01:00" level=info msg="registered user checker: http"
time="2024-11-03T16:36:59+01:00" level=info msg="registered superuser checker: http"
time="2024-11-03T16:36:59+01:00" level=info msg="redisCache activated"
2024-11-03 16:36:59: Opening ipv4 listen socket on port 1883.
2024-11-03 16:36:59: Opening ipv6 listen socket on port 1883.
2024-11-03 16:36:59: Opening websockets listen socket on port 1884.
2024-11-03 16:36:59: Connecting bridge zendure-broker (mqtt-eu.zen-iot.com:1883)
time="2024-11-03T16:36:59+01:00" level=info msg="started go-cache"
2024-11-03 16:36:59: Bridge 7csIB2c3 sending CONNECT
2024-11-03 16:36:59: mosquitto version 2.0.18 running
2024-11-03 16:36:59: Received CONNACK on connection local.7csIB2c3.
2024-11-03 16:36:59: Bridge local.7csIB2c3 sending SUBSCRIBE (Mid: 148, Topic: 7csIB2c3/#, QoS: 0, Options: 0x00)
2024-11-03 16:36:59: Bridge local.7csIB2c3 sending SUBSCRIBE (Mid: 149, Topic: 7csIB2c3/gr058VX4/sensor/device/#, QoS: 0, Options: 0x00)
2024-11-03 16:36:59: Bridge local.7csIB2c3 sending SUBSCRIBE (Mid: 150, Topic: 7csIB2c3/gr058VX4/switch/device/#, QoS: 0, Options: 0x00)
2024-11-03 16:36:59: Received PUBLISH from local.7csIB2c3 (d0, q0, r0, m0, '7csIB2c3/gr058VX4/state', ... (44 bytes))
2024-11-03 16:36:59: Received PUBACK from local.7csIB2c3 (Mid: 147, RC:0)
2024-11-03 16:36:59: Received SUBACK from local.7csIB2c3
2024-11-03 16:36:59: New connection from ::1:49842 on port 1883.
2024-11-03 16:36:59: Client <unknown> disconnected due to protocol error.
[16:37:00] INFO: Successfully send discovery information to Home Assistant.
[16:37:00] INFO: Successfully send service information to the Supervisor.
2024-11-03 16:37:05: Received PUBLISH from local.7csIB2c3 (d0, q0, r0, m0, '7csIB2c3/gr058VX4/state', ... (44 bytes))
2024-11-03 16:37:09: Received PUBLISH from local.7csIB2c3 (d0, q0, r0, m0, '7csIB2c3/gr058VX4/state', ... (137 bytes))
2024-11-03 16:37:10: Received PUBLISH from local.7csIB2c3 (d0, q0, r0, m0, '7csIB2c3/gr058VX4/state', ... (44 bytes))
2024-11-03 16:37:15: Received PUBLISH from local.7csIB2c3 (d0, q0, r0, m0, '7csIB2c3/gr058VX4/state', ... (44 bytes))
2024-11-03 16:37:20: Received PUBLISH from local.7csIB2c3 (d0, q0, r0, m0, '7csIB2c3/gr058VX4/state', ... (44 bytes))
2024-11-03 16:37:24: Received PUBLISH from local.7csIB2c3 (d0, q0, r0, m0, '7csIB2c3/switch/device/gr058VX4buzzerSwitch/config', ... (295 bytes))
2024-11-03 16:37:24: Received PUBLISH from local.7csIB2c3 (d0, q0, r0, m0, '7csIB2c3/sensor/device/gr058VX4solarInputPower/config', ... (260 bytes))
2024-11-03 16:37:24: Received PUBLISH from local.7csIB2c3 (d0, q0, r0, m0, '7csIB2c3/sensor/device/gr058VX4packInputPower/config', ... (256 bytes))
When i am looking in my first broker, i don’t see the new topic , is it normal ?
b3f380b97920434077ad48f74ed446053c2b309e
Thanks for tour help
