armdan
(armdan)
February 9, 2024, 9:38am
1
I want to parse the JSON file from the API where the expiration date is near. here is what I have but it does not work. Also, I am trying to avoid 255 limitation trying to display only expired items.
"data": [
"expiryDate": "2024-02-10",
"description": "item 1"
"expiryDate": "2024-05-10",
"description": "item 2"
- platform: rest
resource: https://some-apilink.com
headers:
Authorization: "Bearer somecodehere"
scan_interval: 14400 # 4 hours
value_template: >-
{%- set items = [] %}
{%- set now = now() %}
{% for row in value_json.data %}
{%- set expiry_date = strptime(row.expiryDate, '%Y-%m-%d') %}
{%- set expiry_date_with_tz = expiry_date.replace(tzinfo=now.tzinfo) %}
{%- set days_until_expiry = (expiry_date_with_tz - now).days %}
{%- if 0 <= days_until_expiry <= 30 %}
{%- set item = row.description + ' expires in ' + (days_until_expiry|string) + ' days' %}
{%- set items = items + [item] %}
{%- endif %}
{% endfor %}
{{ items | join(', ') if items | length > 0 else 'Nothing expiring in 30 days or less' }}
Can you please help? Even ChatGTP could not help me lol.
Troon
(Troon)
February 9, 2024, 9:48am
2
Don’t even go there.
Your issue is one of scope : the items
variable inside the for
loop is not the same as the one outside. Solve this with a namespace :
{%- set ns = namespace(items=[]) %}
{% for row in value_json['data'] %}
{%- set ns.items = ns.items + [item] %}
{%- endif %}
{% endfor %}
{{ ns.items | join(', ') if ns.items | length > 0 else 'Nothing expiring in 30 days or less' }}
armdan
(armdan)
February 9, 2024, 9:59am
3
thank you very much for your fast reply. Your correction works when I test in the developer tab but when I use it in live API, the home assistant gives a limitation error
Invalid state with length 332. State max length is 255 characters.
This was my problem from the beginning.
Troon
(Troon)
February 9, 2024, 10:04am
4
You still have too many items then. As per the error message, a state cannot exceed 255 characters.
In case it helps, you can filter without loops:
{{ value_json['data']|selectattr('expiryDate','>=',now().date()|string)|selectattr('expiryDate','<',(now()+timedelta(days=30)).date()|string)|list }}
armdan
(armdan)
February 9, 2024, 10:06am
5
I get that. Is there any way I can put the output in attributes, not in a state?
Troon
(Troon)
February 9, 2024, 10:08am
6
You can use json_attributes
if you’re using a Rest sensor to pull the data in. More information needed…
You can then use something like the filter above to make a template sensor with filtered attributes.
armdan
(armdan)
February 9, 2024, 10:11am
7
I don’t know how but thank you I will try to figure it out. Don’t want to bother you any further.
