My motion sensor was added as LIGHT going only to ON. I would like to trigger alarm based on this sensor. Should I turn this from LIGHT to SENSOR - or maybe SWITCH?? (please how). Or should I set the alarm event on this LIGHT? In this situation I need to go back to “OFF” state automatically after xx seconds. Also I would like to see those motion sensors (4 together) in some special HA screen and “light” is not proffessional Thank you.
OK seems like the only solution now is to add motion sensor as SWITCH and create automation based on fire_event created by this switch which wil turon it OFF after xx seconds.
How can I create the “motion” icon on the top of the HA screen which show motion event?
Strange thing is that if I use 433MHz motion sensor via RFlink as a light it will turn on immediatelly (from previous OFF state). But if I configure the same motion sensro as SWITCH it will turn on second or third atempt after I manually turn it to OFF. How is this possible?
DAMNED hassio wont start every third-fourth reboot. Many people talking about the same issue without answer. Maybe it will be better to go back to hassbian. Hassio is really in BETA.
I have moved to HASSBIAN instead of HASSIO. HASSIO just freezes (wont start after reboot sometimes). Seems like there is no possibility to add rf motion sensor as a sensor. Only as a light or switch. Now I try to convert this switch into motion sensor via other component.
