What is wrong with this:
# Hue motion sensors
- platform: hue
sensors:
mbr_temperature:
friendly_name: 'MBR Temperature'
entity_id: sensor.mbr_motion_temperature
value_template: '{{ (states('sensor.mbr_motion_temperature') | float + 0.5) | int }}'
The sensor.mbr_motion_temperature exists with a valid value. My only reason for wanting to create the template sensor is to round it. Reporting temperature to 0.01 F is just plain dumb since none of the home sensors have anywhere near that resolution in practice (some claim to have it but I doubt that.) And who needs to know if their bedroom is at 79.65 or 79.63?
The error produced on config check is:
Error loading /config/configuration.yaml: while parsing a block mapping
in “/config/sensors/huesensors.yaml”, line 6, column 9
expected , but found ‘’
in “/config/sensors/huesensors.yaml”, line 8, column 38
The complete huesensors.yaml is listed above. What looks like 1 space indent is actually 2 in the text file.
I should also add that the stuff after value template produced correct results in the HA template checker.
