I used the plex sensor because I couldnt get the normal Plex component to work - if you’re using it for the same reason, then you’d be happy to know that if you manually create the plex.conf file, the Plex component will work as expected.
ok I did that as well, but since you never know who’s watching but only how many people are, it’s hard to have it precise. I suggest you set up the main Plex component and use this one as a trigger!
@weissblut could you possibly share some of the automation configuration? I am trying to use this plex activity monitor to turn of the server if it is not being used for 30 minutes.
Ive updated the way my automation for lighting and other things are triggered from plex. Im now using the mqtt features of tautulli. It give greater control you can filter by device, movie, pause, play, end of movie etc. You can even have it ignore the preroll/previews. Have the lights kick on when movie is considered “watched”. Tautulli with the mqtt notification feature really took the plex automations to the next level. I can even trigger things in different rooms based on the clients and the mqtt topics that are posted to.
