I see that in the Plex Component it states: “The Plex component does not currently support HTTPS.”
Is this referencing if using HTTPS on HA or on Plex? I’m not sure why my Plex is no longer recognized in HA, but I do have HTTPS enabled on HA.
Using HTTPS on HA should not influence functioning of Plex.
See https://github.com/home-assistant/home-assistant/issues/891 for more details, but it is only an issue if your Plex server is set to SSL-only/strict. If you allow non-https connections to the Plex server, then it should still work.
