HI
have been getting these Plex errors since forever.
Only now do i spot this line with the 443 port at the bottom of the snippet below:
Is this interfering with the portfrowaridng in the router for Letsencrypt?
Ive never put it in any configuration for Plex, so my hopes are on you to confirm or correct this if you could please?
Thanks,
Marius
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 171, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File "/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/plex.py", line 55, in setup_platform
plex_token)], True)
File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/plex.py", line 74, in __init__
user = MyPlexAccount(plex_user, plex_password)
File "/usr/lib/python3.6/site-packages/plexapi/myplex.py", line 78, in __init__
data, initpath = self._signin(username, password, timeout)
File "/usr/lib/python3.6/site-packages/plexapi/myplex.py", line 86, in _signin
data = self.query(self.SIGNIN, method=self._session.post, auth=(username, password), timeout=timeout)
File "/usr/lib/python3.6/site-packages/plexapi/myplex.py", line 146, in query
response = method(url, headers=allheaders, timeout=timeout, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 555, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 508, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='my.plexapp.com', port=443): Max retries exceeded with url: /users/sign_in.xml?X-Plex-Token=None (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x71bb7f70>: Failed to establish a new connection: [Errno -2] Name does not resolve',))
