Plex authorisation issues
I’m trying to set up the plex server component but I keep getting this:
plexapi: http://192.168.0.26:32400: (401) unauthorized
I’ve put the token into the configurator, and it’s created a plex.conf, but it still doesn’t seem to work.
Any ideas?
You could also try adding your HA’s IP in the settings in Plex. Under the server in the network options look for “List of IP addresses and networks that are allowed without auth”. You may have to show the advanced settings.
Also just make sure that token hasn’t changed for some reason.
Tried that but didn’t seem to make a difference. Unless you need to restart Plex for that setting to take effect?
Token is still correct.
I don’t remember restarting after I added this.
Did you get this to work @Soul? I have the exact same problem, even tried to do a curl command with the token in - got a lot of data back, so et seems to be to be a HA problem perhaps?
Yes it seems to be working now. I’ve got a plex.conf file with my token in it and it seems fine.
