Plex component errors when server is down
I have the Plex server running on a computer that is off during the day. Since the Plex component cannot connect to the server, it justs keeps spitting errors to the log (to the point where I can’t even see the log on the developer panel!). Is there any fix to this?
If there’s no way to stop it from logging errors, is there a way to disable the component and hide the configurator?
Ok, just added a pull request to fix this since there was no way around ( https://github.com/home-assistant/home-assistant/pull/8179 ). Also, to prevent the errors from showing (after the pull request is merged) this should be added to the logger: homeassistant.components.media_player.plex: fatal
