Plex Intergration reload when server is up
Hello all you very clever people :slight_smile:
I have a bunch of servers that turns off doing the night to save power.
One of them is my Plex server.
My problem is that HASS is on 24/7 and when I turn off plex HASS says “failed to setup”
I would like an automation that restart the integration when my Uptime Kuma integration tells HASS that plex is up again.
Is this possible somehow? At the moment I have an automation that restarts HASS when Plex is up…this is not the best solution :frowning:
Thank you all in advance! :slight_smile:
/Thrawn
I reload my LGWebOS integration using the homeassistant.reload_config_entry service action, using one of the entities in the integration, doesn’t seem to matter which one. Maybe try that
See below for finding entry ID if needed:
That is just brilliant! Thank you so munch for your time and amazing help :slight_smile:
Do you know if it’s possible to do the same with the networks share feature? So I could reload it when my servers are up?
No I don’t sorry
No problem :slight_smile: thank you anyway
