How did it go for you? did it help my card?, maybe wanna share yours?
Sorry to ask in your post but it seemed to me that I was asking something similar.
My home assistant is this:
I am trying to correct everything she did and adapt it to my needs.
When I get home from work I try what they told me. The documentation I already read it. I donât know English and the translation is sometimes not good. One of my problems was the permissions I had on the www folder. The last thing I did is correct that and plex created a folder under www. On that side I think heâs doing something.
The port opened it following the documentation. If I look at the open ports they are not visible. I donât know if they should be seen.
http://192.168.0.115:32400 I did not try with https
Iâm still the same, you can see the images of the different configurations. Only with the ip the sensor is online but empty.
If I want to enter by url it works fine
- platform: plex_recently_added
token: !secret plex_token
host: !secret plex_host
port: !secret plex_port
Before
plex_token: xxxxxxxxBD5Ed
plex_host: 192.168.0.115
plex_port: 32400
After
plex_host: https://192.168.0.115
plex_port: 32400
I donât know if itâs a mistake. If I enter by url it asks me to log in: http://192.168.0.115:32400/
Here is mine and it works:
name: Recently Added tv-shows
token: xxxxxxxxxxxxxxxxxxxxxxxx
host: 192.168.178.200
port: 32400
max: 10
section_types:- show
But in any case if the IP cant be reached tray a tracert to see where it stops.
that will go stet by step from the home assistant host to the plex server and see where it stops.
but is simple, is not home assistant, the host device cant reach the ip 192.168.0.115. whatâs the IP of your home assistant instance?
By the way
if you are doing this:
plex_port: 32400
take away the "https:// " on the host part it only needs the ip
If I access from a Chrome with the IP, it enters plex. The error that was seen in the previous log was because the pc was turned off.
Home assistantâs ip is 192.168.0.2 and itâs on the same network. I hope the problem is not that the raspbery pi is in an environment.
The configuration of plex recently add is only with the ip.
What I do not understand is why it is shown online and yet the sensor is empty
Thank you very much for sharing your configuration, I will try when I return from work
First I had a problem with the windows firewall as it did not accept pings from outside.
Once I deactivated it, I did a traceroute from the rasp to the ip of the windows where the plex server is hosted.
Solved it without problem.
I removed the plex server integration and recently added and reinstalled them.
Everything remains the same. The sensor is still empty.
I will not have configured something in the plex server
I still canât solve the problem. When I find the solution I will share it
i tried to play a movie, but i always get :
Media could not be found: { âlibrary_nameâ: âMoviesâ, âtitleâ: âTexas Chainsaw Massacreâ, âyearâ: â2022â }
here is my card :
type: picture-elements
image: ' '
elements:
- type: custom:config-template-card
entities:
- sensor.plex_recently_movies_poster_1
- sensor.neue_filme
- sensor.plex_recently_movies_play_movie_1
card:
type: custom:hui-picture-card
title: Movie 1
image: ${states['sensor.plex_recently_movies_poster_1'].state }
tap_action:
action: call-service
service: media_player.play_media
service_data:
entity_id: media_player.plex_plex_for_android_tv_aftmm
media_content_type: movie
media_content_id: ${states['sensor.plex_recently_movies_play_movie_1'].state }
style:
top: 44%
left: 30%
width: 13%
border: 2px solid gold
is the problem that sensor.plex_recently_movies_play_movie_1 has this as value?
{ "library_name": "Movies", "title": "Texas Chainsaw Massacre", "year": "2022" }
i get a second error:
Library 'Movie' not found
can you please help?
First, make sure your library name is correct. Your script says âMoviesâ but the error says âMovieâ.
Otherwise this might be related to media_player.play_media not able to find Plex libraries ¡ Issue #66659 ¡ home-assistant/core ¡ GitHub. Any chance youâve added leading spaces to your library names to reorder them?
Also look how mine does not have spaces.
[sensor.plex_recently_movies_play_movie_1]
Movie 1 play button
{ âlibrary_nameâ: âMoviesâ, âtitleâ: âEiffelâ, âyearâ: â2021â }
Regards
yeah you are right this was a typo, my library has the name âFilmeâ
no i use no leading spaces.
here are my libraries
<Directory allowSync="1" art="/:/resources/movie-fanart.jpg" composite="/library/sections/1/composite/1645268657" filters="1" refreshing="0" thumb="/:/resources/movie.png" key="1" type="movie" title="Filme" agent="tv.plex.agents.movie" scanner="Plex Movie" language="de-DE" uuid="3108dac9-38f3-4db2-ab11-9cf2f42f41b2" updatedAt="1641735154" createdAt="1640286404" scannedAt="1645268657" content="1" directory="1" contentChangedAt="3719122" hidden="0">
<Location id="12" path="/12TB/12TB/IMAX"/>
<Location id="1" path="/12TB/12TB/Filme"/>
<Location id="2" path="/12TB/12TB/Filme 4K"/>
<Location id="3" path="/10TB2/10TB/Filme/1080"/>
<Location id="4" path="/10TB2/10TB/Filme/4K"/>
<Location id="5" path="/10TB/8TB-2/4K"/>
<Location id="6" path="/3TB"/>
<Location id="7" path="/8TB/4K"/>
then i tried it with a movie called âsource codeâ, but no luck.
media_content_id: >-
{ "library_name": "Filme", "title": "Source Code ", "year": "2011"
i put the aboce code direct in the widget to test it, but no luck he always said,
homeassistant.exceptions.HomeAssistantError: Media could not be found: { "library_name": "Filme", "title": "Source Code ", "year": "2011" }
You may see more info on why it failed in the home-assistant.log file.
I found the problem. I had 2 libraries with the same name filme.
I deleted one of them and now it works fine.
But has Someone the same problem that lovelance says he canât find the hui-picture-card ?
It worked but now it stops, when I open âadd new widgetâ it works and the card get loaded.
is it possible to hide the watched movies?
he saves the âflagâ status, this is the watched or?
