I can’t seem to figure out how to update my plex integration in HA after a password change.
When I click on integrations > plex > cog, I just get a spinning circle loader that never ends.
Short of deleting the integration altogether, and losing everything, I’m lost…
Which password changed? Your Plex account password?
My Plex PW was changed. It then logged everything I had logged in, out of Plex. HA immediately stopped connecting to it.
That’ll invalidate any existing tokens. Are you seeing log messages like “Login to <plex_server> failed, verify token and SSL settings: …” in your HA logs?
If so, the current “fix” to this is to remove the integration and re-add. I’ll look into making a change to handle this in the future.
Thanks. Yeah I was aware the token was invalidated. I was simply hoping to not need to delete the integration and re-add it back. I appreciate the clarification on the path forward however.
