Hey everyone so I setup the Plex sensor and it working fine but I noticed in the logs it is trying to connect to a private IP. I don’t use this range and never have. Here is the full error:
2017-10-30 18:55:51 ERROR (Thread-5) [plexapi] http://172.31.1.100:32400: HTTPConnectionPool(host='172.31.1.100', port=32400): Max retries exceeded with url: /?X-Plex-Token=token (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x7fb4ce9f3470>: Failed to establish a new connection: [Errno 101] Network unreachable',))
It works fine otherwise. I also have the Plex media player add in but I’ve tried completely removing that and it doesn’t fix it. It’s like there is a config file it is pulling from but I don’t know which one.
Thanks for any help!
