Plex Webhooks and Home Assistant
Okay, this is the first one that came up:
17-02-19 12:43:02 ERROR (MainThread) [homeassistant.helpers.condition] Error during template condition: UndefinedError: ‘Player’ is undefined
Update: Okay, I’m getting something that looks like this:
17-02-19 13:21:02 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.5/site-packages/aiohttp/web_server.py", line 62, in handle_request
    resp = yield from self._handler(request)
  File "/usr/local/lib/python3.5/site-packages/aiohttp/web.py", line 270, in _handle
    resp = yield from handler(request)
  File "/usr/local/lib/python3.5/asyncio/coroutines.py", line 213, in coro
    res = yield from res
  File "/usr/src/app/homeassistant/components/http/__init__.py", line 427, in handle
    result = yield from result
  File "/usr/src/app/homeassistant/components/api.py", line 311, in post
    body = yield from request.text()
  File "/usr/local/lib/python3.5/site-packages/aiohttp/web_reqrep.py", line 394, in text
    return bytes_body.decode(encoding)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xff in position 1993: invalid start byte
17-02-19 13:21:15 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/src/app/homeassistant/components/api.py", line 312, in post
    data = json.loads(body) if body else None
  File "/usr/local/lib/python3.5/json/__init__.py", line 319, in loads
    return _default_decoder.decode(s)
  File "/usr/local/lib/python3.5/json/decoder.py", line 339, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/local/lib/python3.5/json/decoder.py", line 357, in raw_decode
    raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
hass@home-server:~/.homeassistant$
It seems to me as though Home Assistant does not accept UTF-8.
Update 2:
And I almost forgot. This is what I have so far:
  plex_webhook:
    alias: "Plex Webhooks"
    sequence:
      - condition: template
        value_template: '{{ Player.uuid == "..." }}'
      - service: script.turn_on
          entity_id: script.plex_webhook_play
          entity_id: script.plex_webhook_stop
  plex_webhook_play:
    alias: "Plex Webhook - Play"
    sequence:
      - condition: or
        conditions:
          value_template: '{{ event == "media.play" }}'
          value_template: '{{ event == "media.resume" }}'
      - service: light.turn_off
          entity_id: light.living_room_floor_lamps
  plex_webhook_stop:
    alias: "Plex Webhook - Stop"
    sequence:
      - condition: or
        conditions:
          value_template: '{{ event == "media.pause" }}'
          value_template: '{{ event == "media.stop" }}'
      - service: light.turn_on
          brightness: 128
There’s an issue surrounding the decoding of JSON:
So I’ll have to go with node.js for now.
FYI this is still an issue. The problem is HA does not handle multipart paylods which is what plex uses unfortunately.
So still no way to get direct connection between webhooks and HA ? it’s bad as we can now get an efficient control if you are using PMP players so feedback like that to go with would be really nice !
For a long time I have been wanting the ability to script different hue light scenes to come on based on what TV show was playing on my plex server (like all red lights when I am watching the strain). Is this something this would be able to do? Most of this tech jargon is written in klingon to me.
@Blinkwise you can already control your light based on play/paused status of your plex player (only drawback is that it takes around 3s between change of state in player and update to HA, that’s why people are looking for a more efficient way to interact with Plex Media Server :wink:
@vincen yeah I got the play/paused thing down for dimming the lights, but I am looking to specifically chance to a hue scene based on whats plays (ie red and yellow lights when I start watching the flash).
Yes this would be doable with this. You could parse the json which has a lot of metadata. I already do stuff like that with emby. But the webhook there does work with HA.
~Cheers
@Blinkwise hum I think you can already do it as HA got hese at least name of media playing so I guess it’s just a question to find the correct filter in your script to change color of light depending of media played or media genre ? red for horror, pink for love movie, green for kids stuffs… :wink:
In case you don’t want to add an additional node.js server, I wrote a small Python daemon which does the necessary translation between Plex and Home Assistant: https://github.com/lorenzschmid/pyTransferMultipart
Awesome work! Thanks for that!
~Cheers
Hi - can you explain how things would work differently with the new Webhook Trigger in HA 0.80?
Any update re triggering an automation from Plex using the new Webhook Trigger?
Did anyone get the plex webhooks to work? With the update of webhooks I was under the impression it would be possible to use this just with standard automations and scripts. I was looking forward to this but can’t find any documentation on this.
What URL should be used on the plex side? e.g. https://myurl.duckdns.org:8123/api/webhook/plex_user
Do you need anything in Home Assistant configuration? (don’t think so?)
How can you read the diferent payloads? (to use as conditions) (E.g. only if media.player = tv and action is media pause)
Thank you all for the help.
Don’t know for sure as I don’t have plex but my guess would be that it still is not compatible as plex sends multipart forms.
This seems to be a suitable workaround, it worked for me.
Using webhooks from plex and the Nabucasa Cloud I got it all working.
Automation to read the webhook to MQTT
- alias: Plex - Webhook - to MQTT
    platform: webhook
    webhook_id: !secret webhook_plex
   - service: mqtt.publish
     data_template:
       topic: 'plex/update'
       payload_template: >
         {{ (trigger.data | string)[154:][:-55] | replace ("\\\\", "\\") | replace ("\\\'", "'") | replace ("\\x","?") }}
After that I have a input_boolean that sees if something is playing. (add correct names, uuid, …)
- alias: Plex - Webhook - Toggle Living Room Boolean
    platform: mqtt
  condition:
    condition: and
    conditions:
      value_template: "{{trigger.payload_json.Account['title'] == 'user name' }}"
      value_template: "{{trigger.payload_json.Player.title == 'player name'}}"
      value_template: "{{trigger.payload_json.Player.uuid == 'player id'}}"
      value_template: "{{trigger.payload_json.event != 'media.scrobble'}}"
      value_template: "{{trigger.payload_json.event != 'media.rate'}}"
    service_template: >
        {% if ((trigger.payload_json.event == 'media.play') or (trigger.payload_json.event == 'media.resume')) %}
          input_boolean.turn_on
        {% elif ((trigger.payload_json.event == 'media.pause') or (trigger.payload_json.event == 'media.stop')) %}
          input_boolean.turn_off
        {% endif %}
    entity_id: input_boolean.plex_livingroom
Adn then the state of the inpu_boolean will start the scripts.
- alias: Plex - Licht - Beneden
  - platform: state
  condition:
    data_template:
      entity_id: >
        {%- if states('input_boolean.plex_livingroom') in ['on'] -%}
          script.plex_on
        {%- elif states('input_boolean.plex_livingroom') in ['off'] -%}
          script.plex_off
        {% endif %}
I know it is not very condensed but I like to seperate my automations in steps for debugging.
The only problem I seem to have is that most of the times it won’t fire on first play. This means I have to pause and the play agin to fire the scripts. No idea why.
Anyone any thoughts please?
After some research I understand that this is because plex sends a picture on the first play to the MQTT. Does anyone found a solution for this? Or how to read the play MQTT ? (The lights don’t turn down on play, only on resume)
