Plex works, it shows what’s playing in Home Assistant, I can play & pause, but my logs are constantly showing a lot of red, over & over, for Plex.
2022-08-04 22:37:05 ERROR (SyncWorker_7) [homeassistant.components.plex.server] Resource connection failed to plex.tv: Chrome
2022-08-04 22:37:05 ERROR (Thread-193) [plexapi] http://192.168.#LAN.IP#:32400: Client not found at http://192.168.#LAN.IP#:32400
2022-08-04 22:37:05 ERROR (Thread-192) [plexapi] https://192-168-#LAN-IP#.6f...SAME-STRING-I-BELIEVE-A-UNIQUE-KEY...4e.plex.direct:32400: Client not found at https://192-168-#LAN-IP#.6f...SAME-STRING-I-BELIEVE-A-UNIQUE-KEY...4e.plex.direct:32400
2022-08-04 22:37:08 ERROR (Thread-194) [plexapi] https://#WAN-IP#.6f...SAME-STRING-I-BELIEVE-A-UNIQUE-KEY...4e.plex.direct:#MY-REMOTA-ACCESS-PORT#: HTTPSConnectionPool(host='#WAN-IP#.6f...SAME-STRING-I-BELIEVE-A-UNIQUE-KEY...4e.plex.direct', port=#MY-REMOTE-ACCESS-PORT#): Max retries exceeded with url: /resources (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x000001FC850B0CA0>, 'Connection to #WAN-IP#.6f...SAME-STRING-I-BELIEVE-A-UNIQUE-KEY...4e.plex.direct timed out. (connect timeout=3)'))
2022-08-04 22:37:08 ERROR (Thread-195) [plexapi] http://#WAN.IP#:#MY-REMOTW-ACCESS-PORT#: HTTPConnectionPool(host='WAN.IP', port=#MY-REMOTE-ACCESS-PORT#): Max retries exceeded with url: /resources (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x000001FC850B0D60>, 'Connection to #WAN.IP# timed out. (connect timeout=3)'))
2022-08-04 22:37:08 ERROR (SyncWorker_7) [homeassistant.components.plex.server] Resource connection failed to plex.tv: Chrome
2022-08-04 22:47:05 ERROR (SyncWorker_1) [homeassistant.components.plex.server] Resource connection failed to plex.tv: Chrome
2022-08-04 22:47:05 ERROR (Thread-237) [plexapi] http://192.168.#LAN.IP#:32400: Client not found at http://192.168.#LAN.IP#:32400
2022-08-04 22:47:05 ERROR (Thread-236) [plexapi] https://192-168-#LAN-IP#.6f...SAME-STRING-I-BELIEVE-A-UNIQUE-KEY...4e.plex.direct:32400: Client not found at https://192-168-#LAN-IP#.6f...SAME-STRING-I-BELIEVE-A-UNIQUE-KEY...4e.plex.direct:32400
2022-08-04 22:47:08 ERROR (Thread-238) [plexapi] https://#WAN-IP#.6f...SAME-STRING-I-BELIEVE-A-UNIQUE-KEY...4e.plex.direct:#MY-REMOTE-ACCESS-PORT#: HTTPSConnectionPool(host='#WAN-IP#.6f...SAME-STRING-I-BELIEVE-A-UNIQUE-KEY...4e.plex.direct', port=#MY-REMOTE-ACCESS-PORT#): Max retries exceeded with url: /resources (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x000001FC8531EB50>, 'Connection to #WAN-IP#.6f...SAME-STRING-I-BELIEVE-A-UNIQUE-KEY...4e.plex.direct timed out. (connect timeout=3)'))
2022-08-04 22:47:08 ERROR (Thread-239) [plexapi] http://WAN.IP:#MY-REMOTE-ACCESS-PORT#: HTTPConnectionPool(host='#WAN.IP#', port=#MY-REMTE-ACCESS-PORT#): Max retries exceeded with url: /resources (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x000001FC8531EC70>, 'Connection to #WAN.IP# timed out. (connect timeout=3)'))
2022-08-04 22:47:08 ERROR (SyncWorker_1) [homeassistant.components.plex.server] Resource connection failed to plex.tv: Chrome
2022-08-04 22:48:55 ERROR (SyncWorker_10) [homeassistant.components.plex.server] Resource connection failed to plex.tv: Chrome
2022-08-04 22:48:55 ERROR (Thread-249) [plexapi] http://192.168.#LAN.IP#:32400: Client not found at http://192.168.#LAN.IP#:32400
2022-08-04 22:48:55 ERROR (Thread-248) [plexapi] https://192-168-#LAN-IP#.6f...SAME-STRING-I-BELIEVE-A-UNIQUE-KEY...4e.plex.direct:32400: Client not found at https://192-168-#LAN-IP#.6f...SAME-STRING-I-BELIEVE-A-UNIQUE-KEY...4e.plex.direct:32400
This snippet was taken at a different time from the screenshot, but the log is filled with the same things over & over.
I tried restarting, I tried removing Plex & re-adding it, but nothing has fixed it.
I’ve looked for a solution, but everything I find is completely different, being about the sensors being unavailable or about it having an error while setting up the platform.
I look at the console &, right now, it’s pages & pages of red, all the same things over & over, with a random spot of green every couple pages of red.
Any help would be appreciated. I’m at a complete loss.
