I am trying to get thermostat data from the Tuya cloud.
The thermostat is made by Plikc and they are using a custom mobile app to communicate with their devices.
I did some tests and found the correct endpoint and parameters to send to it (apart from the “sign” field, this is still a big unknown).
Do you have any knowledge about this manufacturer’s thermostats? Or some guide to correctly calculate the sign (and possibly other parameters) to send to the endpoint?
If this interests you, I can share the endpoint I found and the related fields to fill out in the request.
Hi, it seems nobody needed Plikc integrations until now.
I don’t have a thermostat but a switch (astro wifi) PLK202020. It seems they are using Tuya cloud too. I will be trying to get things working in the following days.
Seems like one of the very few chronotermostats which can be configured both on the device itself and through the app. That is, one of the few devices that are more than a dumb switch when the cloud link/wifi is down.
Hi, in fact the integration is already working if you use “Smart Life App” instead of “Plikc App”. They are very similar. Then you can use “Tuya” integration of Home Assistant.
There is however a little bug in the exposed operations… see screenshot (two “Caldo/Freddo” buttons).
Hi ! I have 3 of these thermostats, and yes, there is some bugs with Tuya integration. I even tried with Local tuya but it gave me problems with endpoints. I hope that Tuya (or Loc Tuya) will integrate it soon.
Hi!,
i am also trying to integrate this thermostat into home assistant. After successfully configuring it on smart life app, in ha as tuya integrations i have only 1 entity as switch. So I can only turn it on and off. Instead, I would like to be able to integrate the complete thermostat, with the status, the current temperature, etc.
Ciao a tutti sono un neofita di ha. Anch’io possiedo un termostato neve, qualcuno sa se adesso è compatibile con ha? Poter fare tutte le operazioni e non solamente accendere/ spegnere
Grazie mille
Hello everybody,
I managed to integrate Plikc Neve X Pro W with Tuya/Tuya local.
I didn’t manage to add a complete climate entity to Tuya local but I’ll probably use come custom thermostat integration…
Here the steps to add the device to Tuya AND Tuya local integrations:
add the device to Tuya Smart app (dont’worry: identical settings of Plikc app); if it’s been already added to to Plikc remove it resetting the device using the procedure described on the user manual;
add the Tuya integration on Home assistant;
add the device on the Tuya integration; this integration is bugged (every temperature change reverts the mode to “manual” disabling the weekly program; and there are 3 heat/cold settings but it’s only a easthetical issue);
add Tuya local integration on Home assistant;
add the device and the entities: the binding of some endpoints/DPS to the entities is not editable (if you don’t want to delete and re-create a new device on Tuya local integration):
5.1. number entity for ID=16, target temperature, min=50, max=350;
5.2. sensor entity for ID=24, for current temperature, class=temperature, scale=0,1;
5.3. binary_sensor entity for ID=1, for thermostat on/off state;
5.4. select entity for ID=2, for mode, options=manual;auto;holiday;temporary
There are other DPS if useful to be added:
DPS
Description
1
power on
2
mode
3
16
target temp
19
max target temp
24
current temp
26
min target temp
27
temp correction
32
holiday_temp_set
33
holiday_days_set
39
NOT_factory_reset
40
child_lock
42
countdown_left
45
fault
I’m not an expert, but it there are questions I’d be pleased to help…
Thank you for the guide you posted above. I added the Neve X W to local Tuya and was able to add it as a device in Home Assistant. However, all entities I have configured are listed as “Unavailable”:
