Plotly interactive Graph Card
Ok, now this solved the first wrong value when accesing the card:
type: custom:plotly-graph
hours_to_show: 168
defaults:
  yaxes:
    fixedrange: true
layout:
  xaxis:
    rangeselector:
      'y': 1.25
      buttons:
        - count: 1
          step: day
        - count: 7
          step: day
        - count: 1
          step: month
        - count: 1
          step: year
entities:
  - entity: sensor.salon_heating_equivalente_today
    statistic: sum
    period:
      0s: hour
      24h: hour
      7d: day
      1M: day
      6M: month
      1y: month
    name: Horas calefaccion equivalentes
    unit_of_measurement: h
    type: bar
    filters:
      - filter: i>0
      - derivate: |
          $ex {
             const [start, end] = get('visible_range');
             const dist = +end-start;
             const day = 1000*60*60*24;
             const month = day*30;
             if (dist <= day) return 'd';
             if (dist <= month) return 'd';
             return 'M';
refresh_interval: 10
But when pressing any of the buttons that modified the period , the values are still wrong:
1d button: More then 18h in 1h period seems impossible to me
1M button:
! year button is not charguing anything, I guess because the 1 year period : 1 month is not completed yet??
I have a graph with my current power consumption and the production of power of my small solar panels.
I’d like to have a seperate graph with my EV charging and have this substracted from my total power consumption graph, as the 11kw show as huge spikes. Is it possible? There is no substract filter and i’m not very clear how to solve this. Thanks!
Hi @mateine , more on this graph.
I compared my graph bar with the actual variable I want to represent and detected more strange behavior.
For example, the variable is recording values since february 17th but the bar graph is only showing values since february 20th:
Do you think this is a wrong configuration of the statistics graph or it’s a bug?
I paste the code again as I did some minor changes to test them:
hours_to_show: 168
defaults:
  yaxes:
    fixedrange: true
layout:
  xaxis:
    rangeselector:
      'y': 1.25
      buttons:
        - count: 1
          step: day
        - count: 7
          step: day
        - count: 1
          step: month
        - count: 1
          step: year
entities:
    statistic: sum
    period:
      0s: hour
      24h: hour
      7d: day
      1M: day
      6M: month
      1y: month
    type: bar
    filters:
      - filter: i>0
      - derivate: |
          $ex {
             return 'M';
Looking for advice - so I have few sensors. Some are statistic sensors such as:
state_class: total_increasing
source: sensor.meter_electric_consumption_kwh
status: collecting
last_period: 12.9
last_valid_state: 13819.8
meter_period: daily
cron pattern: 0 0 * * *
last_reset: 2024-02-26T23:00:00.009322+00:00
unit_of_measurement: kWh
device_class: energy
friendly_name: daily_energy
While others just have certain value:
friendly_name: Daily self consumed energy
I currently use graph using apex chart card that displays both correctly. However using plotly, second one is not displayed.
Example card is:
entities:
  - entity: sensor.daily_self_consumed_energy
      $fn ({ ys,meta }) =>
        "Self" + "(" +ys[ys.length ]+" kWh)"
    type: bar
    statistic: max
    period: day
    texttemplate: '%{y}'
    marker:
      color: green
  - entity: sensor.daily_energy
        "From Grid" + "(" +ys[ys.length - 1]+" kWh)"
    type: bar
    statistic: state
    period: day
    marker:
      color: red
hours_to_show: 5d
layout:
  xaxis:
    rangeselector:
      'y': 1.2
      buttons:
        - count: 7
          step: day
        - count: 14
          step: day
        - count: 30
          step: day
  yaxis:
    fixedrange: true
It displays sensor.daily_energy sensor just fine, however other is not, regardless if I use max, mean or min. How can I do that?
I get this instead:
With Apex, I get something like this:
Appreciate the help
Can check against the standard statistics card in home assistant?
Statistics with period beyond 5minutes should be stored forever
Try removing the ā€œstatisticā€ key for sensors without statistics. Also i suggest you remove the first datapoint when using bar charts with a filter like this: filter: i>0
Ok changed it tk this, but it still does not show. + When I scroll through the graph, bars chage their thickness.
entities:
        "Self" + "(" +ys[ys.length ]+"kWh)"
    type: bar
    period: day
    filter: i>0
    marker:
      color: green
        "From Grid" + "(" +ys[ys.length - 1]+"kWh)"
    type: bar
    statistic: state
    period: day
    filter: i>0
    marker:
      color: red
hours_to_show: 5d
layout:
  xaxis:
    rangeselector:
      'y': 1.2
      buttons:
        - count: 7
          step: day
        - count: 14
          step: day
        - count: 30
          step: day
  yaxis:
    fixedrange: true
filters:
  - filter: i>0
See this section GitHub - dbuezas/lovelace-plotly-graph-card: Highly customisable Lovelace card to plot interactive graphs. Brings scrolling, zooming, and much more!
There is a gap in the 19th and also the value the 20th is different in the HA-card. The 18th doesn’t appear in plotly
Changing to 1 day graphs and period to hour, it can be see the bars are similar but the valors are completely illogical in plotly whereas in HA native card the have a logical value each hour
Changing to 1 month does’t change the native statistics card, as there is only dates since the 17th, but the values seem again to be logical, whereas in plotly the bars seems to be proportionally correct but the values aren’t.
Thank you. So I changed my template sensor to:
friendly_name: Daily Self Consumed Energy
But it still shows ā€œundefinedā€ for the value in the name, and there is no graph displayed. I also tried to remove ā€œstatisticā€ as you recommended, but that did not change anything. Is there anything else that I am not getting?
it will take some time for the sensor statistics to be collected and stored. Give it a couple of days
i would like to open a subview. Thought i’d do that by double clicking.
on_dblclick: |-
  $fn ({ hass }) => () => {
    hass.callService('light', 'turn_on', {
      entity_id: 'light.portique_lumiere'
But the doubelclick does not support navigation actions or does it? the default tap_action is not supported either right?
  tap_action:
    action: navigate
    navigation_path: /lovelace/living_room
i found this thread where someone found a workaround.
but i cannot get the
window.history.pushState(null,"","/lovelace-main/0");
window.dispatchEvent(new CustomEvent("location-changed"));
to work.
Any ideas on this topic?
Thanks. It took some time but statistics started to work after.
I am trying to display daily consumption. This is what it looks like:
Is there a way how can I move ā€œtotalā€ line graph to the back, so that bars are in the front?
And this is the code:
entities:
  - entity: sensor.hourly_energy
        "Grid" + "(" +ys[ys.length - 1].toFixed(2)+"kWh)"
    type: bar
    filters:
      - filter: i>0
    statistic: state
    period: hour
    marker:
      color: red
  - entity: sensor.hourly_self_consumed_energy
        "Self" + "(" +ys[ys.length - 1].toFixed(2)+"kWh)"
    type: bar
    filters:
      - filter: i>0
    statistic: state
    period: hour
    marker:
      color: rgb(0, 204, 0)
  - entity: sensor.hourly_electricity_exported_to_grid_huawei
        "Export" + "(" +ys[ys.length - 1].toFixed(2)+"kWh)"
    type: bar
    filters:
      - filter: i>0
    statistic: state
    period: hour
    marker:
      color: rgb(230, 230, 0)
  - entity: sensor.hourly_house_total_consumed_energy
        "Total" + "(" +ys[ys.length - 1].toFixed(2)+"kWh)"
    type: line
    line:
      shape: spline
      color: rgb(255, 214, 204)
    fill: tozeroy
    statistic: state
    period: hour
    marker:
hours_to_show: current_day
layout:
  barmode: stack
  xaxis:
    rangeselector:
      'y': 1.2
  yaxis:
    fixedrange: true
One another question. For similar with my water usage, I have values in cubic meters. I display that on the bar, so I get values like ā€œ0.323ā€. How can I multiply it by 1000 to get ā€œ323ā€ value instead? I am using texttemplate: '%{y}'
I have a simple plot but have been unable to disable the two-finger scroll. I’m on a MacBook and every time I scroll down on my dashboard, my plot zooms out when I scroll with two fingers with the mouse over the plot. I’ve set drag mode and scrollZoom both to false, but the behavior does not change. Any suggestions? I would like to not fully disable zooming (by fixing the axes).
Try changing the order of the entities array
try:
entity: sensor.xyz
texttemplate: '%{y:.1f}'
unit_of_measurement: L
filters:
  - multiply: 1000
try:
config:
  scrollZoom: false
Filter worked, thanks.
But the other question regarding graphs - moving entites did not change anything. Line with fill is always in the foreground.
Make sure you’re wrapping the javascript inside of a $fn function that is used to add custom behavior.
Does that help?
on_dblclick: |-
     window.history.pushState(null,"","/lovelace/living_room")
This is a very cool card that I only just discovered from your reference to my my tap_action navigate post. I installed plotly and got it working using the code above.
Ok, I found out why changing the order of the traces/entities doesn’t affect what occludes what. It is because all your entities have the same unit_of_measurement and therefore the same yaxis. In this case it looks like Plotly decides what to do itself.
The trick is to set yaxis yourself:
  - entity: sensor.sensor_background
    yaxis: y
    type: bar
  - entity: climate.sensor_foreground
    yaxis: y2 # <---- here, this forces a new axis and it will be rendered on top.
You can then hide the y2 axis and force it to stay in sync with y
layout:
  yaxis2:
    visible: false
    matches: y
absolutely! :heart: Thanks
Javascript isn’t my forte…
