Plotly interactive Graph Card
This totally worked! thanks.
Thank you for your help. I placed ā€œscrollZoom: falseā€ under a config: section as suggested, but this did not fix my problem. Let me describe the behavior more specifically (in case this helps):
  • If my mouse is not over the plot area (above or below the card) and I put my two fingers on the trackpad and scroll (up, down or back and fourth) the behavior is as expected (no zooming). I can scroll past the Plotly card up and down with no problems as long as I don’t take my two fingers off the trackpad and as long as they are initially placed on the trackpad when my mouse is NOT over the plot.
  • If the mouse is IN the plot area (so the mouse curser is a ā€œplusā€) and then I put my two fingers on the trackpad to scroll up or down, the plot will zoom in or out. The display also scrolls up or down even to the point where the mouse will no longer be over the plot. As long as I keep my two fingers on the trackpad, the plot will also zoom while I’m scrolling, even if my mouse has moved completely off of the graph.
Not sure if there’s any way to fix this, but here is my code:
type: custom:plotly-graph
disable_pinch_to_zoom: true
layout:
config:
scrollZoom: false
margin:
r: 75
dragmode: false
legend:
orientation: h
xanchor: center
x: 0.5
entities:
  • entity: sensor.deye_sunsynk_sol_ark_pv_power
    fill: tozeroy
    line:
    color: gold
    filters:
    • sliding_window_moving_average:
      window_size: 10
      extended: false
  • entity: sensor.deye_sunsynk_sol_ark_load_power
    fill: tozeroy
    line:
    color: blue
    filters:
      window_size: 10
      extended: false
  • entity: sensor.deye_sunsynk_sol_ark_grid_power
    fill: tozeroy
    line:
    color: red
    filters:
      window_size: 10
      extended: false
  • entity: sensor.deye_sunsynk_sol_ark_battery_state_of_charge
    line:
    color: black
    hours_to_show: 24
    refresh_interval: 10
    title: Energy Overview
Please fix the code block formatting and I’ll take a look.
layout:
  config:
    scrollZoom: false
  margin:
    r: 75
  dragmode: false
  legend:
    orientation: h
    xanchor: center
    x: 0.5
entities:
  - entity: sensor.deye_sunsynk_sol_ark_pv_power
    fill: tozeroy
    line:
      color: gold
    filters:
      - sliding_window_moving_average:
          window_size: 10
          extended: false
  - entity: sensor.deye_sunsynk_sol_ark_load_power
    fill: tozeroy
    line:
      color: blue
    filters:
          window_size: 10
          extended: false
  - entity: sensor.deye_sunsynk_sol_ark_grid_power
    fill: tozeroy
    line:
      color: red
    filters:
          window_size: 10
          extended: false
  - entity: sensor.deye_sunsynk_sol_ark_battery_state_of_charge
    line:
      color: black
hours_to_show: 24
AhĆ”, the config doesn’t go inside layout. it goes on the root level
I am using an expression to calculate a range for a y-axis, because I need to exclude a trace. I use getFromConfig(entities) to get the traces, then find min and max for the desired traces.
Can I somehow detect which traces are shown? (Enabled or disabled in the legend)
I want to make a chart with a overview of the energy used and produced in a year. So 2 plots for a month, 24 a year.
Is that possible ? And how do I make it happen ?
That’s unfortunately not supported at the moment. Feel free to open a feature request issue in the repo and I’ll look into it for the next release
yes, that’s possible, look into:
And while you are at it, you may want to read the whole readme and look around in the discussions page.
Hi, discovered this great Plotly extension, and created this power-energy history-graph using some example-code from some examples.
I added a function to add the the ā€˜live’ state info of the entity to this graph. As you can see when using this, the last column is continuously growing. (No energy-export here, due to sun-set :slight_smile:)
title: Plotly
hours_to_show: current_week
time_offset: 8h
stack: false
defaults:
  entity:
    unit_of_measurement: kWh
    texttemplate: '%{y}'
    type: bar
    statistic: state
    period:
      0s: 5minute
      2h: hour
      6d: day
      360d: month
entities:
  - entity: sensor.p1_meter_totale_energie_import
    filters:
      - delta
      - fn: |
          ({xs,ys,hass,statistics}) =>   {
            let statLast = statistics.length-1;
            let lastStatisticsDateTime = new Date(statistics[statLast].end);
            let lastStateDateTime = new Date(hass.states["sensor.p1_meter_totale_energie_import"].last_changed);
            let stateLastStatic = statistics[statLast].state;
            let stateLastState = hass.states["sensor.p1_meter_totale_energie_import"].state
            let state = stateLastState-stateLastStatic;
            if (state>0){
              if (lastStateDateTime.getTime()>lastStatisticsDateTime.getTime()){
                xs.push(lastStatisticsDateTime);
                ys.push(state);
              }else{
                ys[statLast]+=state;
              //debugger
            return ({ xs,ys })
      - store_var: import
      - fn: console.log
      - fn: |
          ({hass}) => {
            console.log(hass.states["sensor.p1_meter_totale_energie_export"])
  - entity: sensor.p1_meter_totale_energie_export
    filters:
      - delta
      - fn: |
            let lastStateDateTime = new Date(hass.states["sensor.p1_meter_totale_energie_export"].last_changed);
            let stateLastState = hass.states["sensor.p1_meter_totale_energie_export"].state
            if (state>0){
                ys.push(state);
              }else{
              //debugger
            return ({ xs,ys })
      - store_var: export
      - fn: console.log
      - fn: |
          ({hass}) => {
refresh_interval: auto
fn: |
  $fn({getFromConfig, vars})=> {
    const range = getFromConfig("visible_range");
    const width = range[1] - range[0];
    vars.scroll = (label, p) => ({
      args: [
          layout: {
            "xaxis.range": [range[0] + width*p, range[1] + width*p],
          transition: {
            duration: 150,
      label,
      method: "animate",
    vars.zoom = (label, h) => ({
      args: [
          layout: {
            "xaxis.range": [Date.now()-1000*60*60*h, Date.now()],
      label,
      method: "animate",
layout:
  barcornerradius: 15
  bargap: 0.1
  bargroupgap: 0.1
  height: 50%
  xaxis:
    tickangle: -45
  updatemenus:
    - buttons:
        - $fn({vars}) => vars.scroll( '<', -.5)
        - $fn({vars}) => vars.scroll( '>', .5)
      direction: right
      active: -1
      pad:
        r: 10
        t: 0
      type: buttons
      x: -0.1
      xanchor: left
      'y': -0.2
      yanchor: top
    - buttons:
        - $fn({vars}) => vars.zoom( '1y', 24*366)
        - $fn({vars}) => vars.zoom( '1m', 24*31)
        - $fn({vars}) => vars.zoom( '1w', 24*7)
        - $fn({vars}) => vars.zoom( '1d', 24)
        - $fn({vars}) => vars.zoom( '1h', 1)
      direction: right
      active: -1
      pad:
        r: 100
        t: 0
      type: buttons
      x: 0.1
      xanchor: left
      'y': -0.2
      yanchor: top
So far so good.
Now I have two questions, maybe some one can help, as I do not find a solution to the questions:
  1. As you can see I copied the code for the ā€˜live’ data for the last bar (the fn: code within the entity sections), and changed to entity-name in the hass.states[ ]. I did so, because I need the name of the entity to get the current state of the entity. My question here is:
    Is this name accessible as a variable, so I can make this one central code?
  2. See these two graphs, both showing the same page.
The upper one is opened at 18:52 hours, and the lower one is opened at 18:56 hours.
As you can see the upper one is continuing to increase in the 18:50 column, while the lower one has a new 18:55 column and is increased there.
I assume that the statistics are not updated while viewing the page. Is there a option to update the statistics within the view-time of this page?
Cool, I see you are really squeezing it really well already! :slight_smile:
Yes, use get('.entity'). The get function (or the alias getFromConfig) grabs stuff from other parts of the config, including defaults and stuff that gets populated as the yaml is interpreted. It can do both absolute (from the root) and relative paths (relative to wherever the function lyes). To do relative paths, just start with a dot.
This feature is designed it to enable the kind of advanced stuff like what you are doing :+1:
To reuse the function, you can:
  • define it at the top and put it in vars, or
  • make it part of the entity defaults.
refresh_interval: auto may not update statistics data. Try changing it to 10s.
Thanks for your reply!!
Using get() works, though I used let entity = get('entities[0].entity') as get('.entity') did not work.
This is my changed code:
title: Plotly
time_offset: 8h
stack: false
entities:
defaults:
  entity:
    type: bar
    statistic: state
    period:
      0s: 5minute
      2h: hour
      6d: day
      360d: month
    filters:
      - delta
      - fn: |
          ({xs,ys,hass,statistics,get,meta}) =>   {
            let lastStateDateTime = new Date(hass.states[entity].last_changed);
            let stateLastState = hass.states[entity].state
            if (state>0){
                ys.push(state);
              }else{
            return ({ xs,ys })
refresh_interval: 5
fn: |
      args: [
          layout: {
          transition: {
            duration: 150,
      label,
      method: "animate",
      args: [
          layout: {
      label,
      method: "animate",
layout:
  barcornerradius: 15
  bargap: 0.1
  bargroupgap: 0.1
  height: 50%
  xaxis:
    tickangle: -45
  updatemenus:
    - buttons:
      direction: right
      active: -1
      pad:
        r: 10
        t: 0
      type: buttons
      x: -0.1
      xanchor: left
      'y': -0.2
      yanchor: top
    - buttons:
      direction: right
      active: -1
      pad:
        r: 100
        t: 0
      type: buttons
      x: 0.1
      xanchor: left
      'y': -0.2
      yanchor: top
Sadly, changing refesh_interval: auto to refresh_interval: 5 did not work. A new bar is not created when the period is over within the view-time of the page. So statistics is not refreshed here also.
I see. Thinking about it, the cache mechansim may not be compatible with statistics, since they update things that happened in the past (which the cache won’t do because it already asked for that period and got nothing).
Feel free to open an issue in the repo.
In fact I have 24 fixed values ( from 24 input_numbers), so it is not a long-term statistics of an entity
it is like this
jan upload : a
jan download : b
feb upload: c
feb download: d
and I need to connect a date to them…
(I think i have to attach an attribute date to it so I can plot it easier ?)
so 1 jan is a b
1 feb is c and d
I think this discussion should get you started Compare current data with historical data over a period of time (e.g. today with yesterday, same day previous year) Ā· dbuezas/lovelace-plotly-graph-card Ā· Discussion #349 Ā· GitHub
Issues created: Created issue
fn: |-
  $ex vars.color = (name) => {
      return getComputedStyle(document.documentElement)getPropertyValue('--'+name);
entities:
  - entity: sensor.energy_grid_consumption
    line:
      color: $ex vars.color('energy-grid-consumption-color')
How did you get the percentage in the top left like that?
Thanks!
Can anyone tell me where to start here?
I have figured out how to set the background color of the plot manually, but the rest of the card is not following the color scheme of HA? I’m a bit confused.
I am trying to move from the seemingly abandoned Apexcharts, but cards not matching everything else would be a dealbreaker. Any help would be appreciated…
title: Cellular Internet Consumption
hours_to_show: 1h
autorange_after_scroll: true
entities:
  - entity: sensor.pfsense_exodus_interface_wan_inbytes_kilobytes_per_second
    line:
      color: rgb(10, 55, 58)
      width: 1
    fill: tozeroy
    fillcolor: rgba(10, 55, 58, 0.25)
    show_value: true
  - entity: sensor.pfsense_exodus_interface_wan_outbytes_kilobytes_per_second
    line:
      color: rgb(255, 152, 0)
      dash: dashdot
      width: 2
    show_value: true
layout:
  height: 250
  margin:
    r: 100
  plot_bgcolor: '#EFDECD'
  xaxis:
    rangeselector:
      'y': 1.2
      buttons:
        - count: 1
          step: hour
          label: Hour
        - count: 1
          step: day
          label: Day
        - count: 7
          step: day
          label: Week
        - count: 28
          step: day
          label: Month
Also, is there a place that lists common options for the various things. Obviously, not all the possibilities, but the readme is a bit lacking in examples. For example, for a line, the options are ā€œdotā€, ā€œdashā€, etc… For an entity, the options are ā€œnameā€, ā€œshow_valueā€, etc…
I couldn’t find that, except in the Plotly documentation, but it’s unclear what applies to Home Assistant.
Great integration, BTW! I appreciate all the work that went into this.
Hi there’s, thanks for the nice words.
This card builds upon a plotting library called plotly, to see all options you need to go to Plotly javascript graphing library in JavaScript
You can also google/chatGPT ā€œhow do I xyz with plotlyjsā€
