New to plotly/JS.
Following config does not produce x-y scatter plot, rather two separate traces with time on x-axle
type: custom:plotly-graph
title: Scatter Graph
entities:
- sensor.esp32_2_inside_humidity
- sensor.esp32_2_inside_temperature
layout:
xaxis:
title: X-Axis
yaxis:
title: Y-Axis
hovermode: closest
- type: scatter
mode: markers
x:
y:
Can someone spot the mistake?
So it sounds like true scatter plots are only supported in the scatter3d mode?
For a 2D plot, what’s the best course of action - flatten a 3D plot?
not only 3d plot but 2d is also possible
Here you are a very simple example:
title: eGolf Charging Curve
entities:
- entity: >-
sensor.p30x_total_charging_current_calc
internal: true
fn: $fn ({ ys, vars }) => vars.curr = ys
- entity: >-
sensor.egolf_battery_level
internal: true
fn: $fn ({ ys, vars }) => vars.soc = ys
- entity: ''
x: $fn ({ vars }) => vars.curr
'y': $fn ({ vars }) => vars.soc
raw_plotly_config: true
layout:
xaxis:
title: Calculated Current (A)
yaxis:
title: SOC (%)
