This causes errors in my logs. Can we avoid them?
Logger: homeassistant.components.sensor
Source: helpers/entity_platform.py:609
integration: Sensor (documentation, issues)
First occurred: 21:08:47 (2 occurrences)
Last logged: 21:08:47
Error adding entity sensor.filtered_heating_in_cond for domain sensor with platform template
Error adding entity sensor.filtered_heating_out_cond for domain sensor with platform template
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 635, in state
numerical_value = int(value)
ValueError: invalid literal for int() with base 10: ''
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 638, in state
numerical_value = float(value)
ValueError: could not convert string to float: ''
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 609, in _async_add_entities
await coro
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 928, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1383, in add_to_platform_finish
await self.async_added_to_hass()
File "/usr/src/homeassistant/homeassistant/components/template/template_entity.py", line 578, in async_added_to_hass
async_at_start(self.hass, self._async_template_startup)
File "/usr/src/homeassistant/homeassistant/helpers/start.py", line 71, in async_at_start
return _async_at_core_state(
hass, at_start_cb, EVENT_HOMEASSISTANT_START, _is_running
File "/usr/src/homeassistant/homeassistant/helpers/start.py", line 36, in _async_at_core_state
hass.async_run_hass_job(at_start_job, hass)
File "/usr/src/homeassistant/homeassistant/core.py", line 940, in async_run_hass_job
hassjob.target(*args)
File "/usr/src/homeassistant/homeassistant/components/template/template_entity.py", line 517, in _async_template_startup
result_info.async_refresh()
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 1126, in async_refresh
self._refresh(None)
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 1312, in _refresh
self.hass.async_run_hass_job(self._job, event, updates)
File "/usr/src/homeassistant/homeassistant/components/template/template_entity.py", line 463, in _handle_results
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1023, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1148, in _async_write_ha_state
self.__async_calculate_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1085, in __async_calculate_state
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1029, in _stringify_state
if (state := self.state) is None:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 642, in state
raise ValueError(
...<5 lines>...
) from err
ValueError: Sensor sensor.filtered_heating_in_cond has device class 'temperature', state class 'measurement' unit '°C' and suggested precision 'None' thus indicating it has a numeric value; however, it has the non-numeric value: '' (<class 'str'>)
Logger: homeassistant.helpers.template
Source: helpers/template.py:2769
First occurred: 20:32:30 (9 occurrences)
Template variable warning: 'null' is undefined when rendering '{{ states('sensor.heating_in_cond') if states('sensor.heating_in_cond')|is_number else null }}'
Template variable warning: 'null' is undefined when rendering '{{ states('sensor.heating_out_cond') if states('sensor.heating_out_cond')|is_number else null }}'
