Before 2021.8 version installed - had Z-Wave Neo Coolcam siren in system.
Siren integration claims “Siren entities are created automatically by integrations that support them.”.
But still have no entities created. Do I need remove and add device again to HA ?
First, you must be using the zwave_js integration for Z-Wave siren support, legacy zwave or ozw integrations do not support sirens. Second, only Z-Wave Sirens that implement the Sound Switch Command Class are supported. The Neo Coolcam siren (NAS-AB01Z) does not support this command class, so you will not get any siren entities for it. Devices like the Aeotec Gen 6 Siren and Zooz ZSE19 are examples of supported Z-Wave sirens.
Thank You very much.
Have right integration (Z-Wave JS), but “wrong” siren.
Would be nice to have more information about supported devices in Siren integration documentation.
My zigbee siren doesn’t appear either
For future folks, you can easily change the sound of the
NAS-AB01Z with a basic zwave set configuration parameter service before you trigger the alarm
For example, to make the sound a doorbell
service: zwave_js.set_config_parameter
parameter: "5"
value: "1"
entity_id: switch.garage_alarm
Full list of parameters here:
https://devices.zwave-js.io/?jumpTo=0x0258:0x0003:0x0088:0.0
