Pls Help! My Android app eating battery so much,run at 16 hrs per day and I have tired almost everything
I tried everything.
  • I disabled every sensor
  • Never on Persistance connection
  • Disabled background access
  • Sensor update frequenzy normal
  • Turn off persistance conection and sensor worker notification
  • Fresh clean install of the app
    (HASS OS lastest version . Android app lastest version )
    The app is on Google Pixel 5
Pls Help, Thanks.
we have some steps outlined here: Troubleshooting | Home Assistant Companion Docs
I see you said a fresh install but if you previously installed the app it does restore potential bad data upon re-install so you should probably follow the start fresh steps as noted in the above link to avoid that.
I Did all that. every step.
Fresh install every step by that guide
I’m experiencing the same thing after the most recent update on a OnePlus 8 Pro
