Pls help with i2s media player
Hi everybody,
I have an ESP32-WROOM-32 set up like this (wiring image at the bottom); only relevant parts, I cropped out wifi etc.
esp32:
  board: esp32dev
  framework:
    type: arduino
i2s_audio:
  i2s_lrclk_pin: 9 #GPIO25
  i2s_bclk_pin: 10 #GPIO26
media_player:
 - platform: i2s_audio
   name: ESPHome I2S Media Player
   dac_type: external
   i2s_audio_id: testy
   i2s_dout_pin: 12 #GPIO14
   mode: mono
### ---> I've found this part when searching for i2s audio issues:
   on_pause:
     - media_player.stop
This is the output I receive when playing an audio file; I specifically chose a very short (<2sec) WAVE audio file hosted on my HASS server. Other media players in my network play this without issues.
[13:07:55][I][app:100]: ESPHome version 2024.5.5 compiled on Jun 15 2024, 13:07:22
[13:07:55][C][wifi:580]: WiFi:
[13:07:55][C][wifi:408]:   Local MAC: 08:B6:1F:29:90:C8
[13:07:55][C][wifi:413]:   SSID: [redacted]
[13:07:55][C][wifi:416]:   IP Address: 10.0.20.250
[13:07:55][C][wifi:420]:   BSSID: [redacted]
[13:07:55][C][wifi:421]:   Hostname: 'i2saudiotest'
[13:07:55][C][wifi:423]:   Signal strength: -73 dB ▂▄▆█
[13:07:55][C][wifi:427]:   Channel: 6
[13:07:55][C][wifi:428]:   Subnet: 255.255.255.0
[13:07:55][C][wifi:429]:   Gateway: 10.0.20.1
[13:07:55][C][wifi:430]:   DNS1: 10.0.20.1
[13:07:55][C][wifi:431]:   DNS2: 0.0.0.0
[13:07:55][C][logger:185]: Logger:
[13:07:55][C][logger:186]:   Level: DEBUG
[13:07:55][C][logger:188]:   Log Baud Rate: 115200
[13:07:55][C][logger:189]:   Hardware UART: UART0
[13:07:55][C][mdns:115]: mDNS:
[13:07:55][C][mdns:116]:   Hostname: i2saudiotest
[13:07:55][C][ota:096]: Over-The-Air Updates:
[13:07:55][C][ota:097]:   Address: i2saudiotest.local:3232
[13:07:55][C][ota:103]:   OTA version: 2.
[13:07:55][C][api:139]: API Server:
[13:07:55][C][api:140]:   Address: i2saudiotest.local:6053
[13:07:55][C][api:142]:   Using noise encryption: YES
[13:07:55][C][audio:214]: Audio:
[13:07:55][C][audio:236]:   External DAC channels: 1
[13:07:55][C][audio:237]:   I2S DOUT Pin: 12
[13:07:55][D][api:102]: Accepted 10.0.0.25
[13:07:55][D][api.connection:1321]: Home Assistant 2024.6.2 (10.0.0.25): Connected successfully
[13:08:05][D][media_player:061]: 'ESPHome I2S Media Player' - Setting
[13:08:05][D][media_player:068]:   Media URL: http://hass.local:8123/media/local/frosch.wav?authSig=eyJhbGciOiJIUzI1NiIsInR5cCI6.....................
WARNING i2saudiotest @ 10.0.20.250: Connection error occurred: [Errno 104] Connection reset by peer
INFO Processing unexpected disconnect from ESPHome API for i2saudiotest @ 10.0.20.250
WARNING Disconnected from API
INFO Successfully connected to i2saudiotest @ 10.0.20.250 in 0.006s
INFO Successful handshake with i2saudiotest @ 10.0.20.250 in 0.095s
Wiring is as follows
color ESP32 i²s board speaker
WHITE GPIO25 LRC x
PURPLE GPIO26 BCLK x
BLUE GPIO14 SD x
GREEN GND GND x
YELLOW VIN V5 x
RED x + +
BLACK x - -
It seems like the board crashes / reboots when I try to play media. Can you please tell me what I did wrong and/or what to do in order to fix this? Thank you in advance for your help :slight_smile:
Hi!
I have the same problem with a “az-delivery-devkit-v4” module (https://mischianti.org/esp32-devkitc-v4-high-resolution-pinout-and-specs/)
My setup is as follows:
ESP32-------MAX98357A
GPIO26------LRC
GPIO25------BCLK
GPIO22------DIN
GND----------GND
+5V------------Vin
GPIO17-------Relay module
When I try to play any media, the ESP32 reboots, even without the MAX98357 module connected. I didn’t have any problems with the internal DAC. Switched to external due to poor sound quality. I did some tests with different pins but no difference.
Has anyone managed to use esp32 with external i2s DAC?
Yaml file:
substitutions:
  friendly_name: Access control
esphome:
  friendly_name: ${friendly_name}
  name_add_mac_suffix: false
  project:
    version: '1.0'
  on_boot:
  - priority: 600 #This is where most sensors are set up.
    then:
    - switch.turn_on: Lamp
  - priority: -100 #At this priority, pretty much everything should already be initialized.
    then:
    - switch.turn_off: Lamp
esp32:
  board: az-delivery-devkit-v4
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: isD1UEPV78Fcf2ZVJRv09pROfJRkbnG1CuzLkWc4D90=
# Allow Over-The-Air updates
ota:
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
  ap: {}
captive_portal:
dashboard_import:
  package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
  import_full_config: true
# web_server:
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO26
    i2s_bclk_pin: GPIO25
media_player:
    name: "WindFang Media Player"
    i2s_audio_id: i2s_in
    dac_type: external
    i2s_dout_pin: GPIO22
    mode: mono
switch:
  - platform: gpio
    pin: GPIO17
    inverted: True
My log:
[D][api.connection:1321]: Home Assistant 2024.6.2 (192.168.68.117): Connected successfully
[D][media_player:061]: 'WindFang Media Player' - Setting
[D][media_player:068]:   Media URL: http://172.30.32.1:8123/api/tts_proxy/69342c5c39e5ae5f0077aecc32c0f81811fb8193_en_-_tts.google_en_com.mp3
[D][media_player:074]:  Announcement: yes
E (1517347) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (1517347) task_wdt:  - loopTask (CPU 1)
E (1517347) task_wdt: Tasks currently running:
E (1517347) task_wdt: CPU 0: IDLE
E (1517347) task_wdt: CPU 1: IDLE
E (1517347) task_wdt: Aborting.
abort() was called at PC 0x4010bd60 on core 0
Backtrace:0x40083925:0x3ffbe9dc |<-CORRUPTED
ELF file SHA256: 0000000000000000
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13132
load:0x40080400,len:3036
entry 0x400805e4
[I][logger:156]: Log initialized
[C][ota:483]: There have been 0 suspected unsuccessful boot attempts.
[D][esp32.preferences:114]: Saving 1 preferences to flash...
[D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[I][app:029]: Running through setup()...
[C][switch.gpio:011]: Setting up GPIO Switch 'Lamp'...
[D][switch:016]: 'Lamp' Turning OFF.
[D][switch:055]: 'Lamp': Sending state OFF
[D][switch:012]: 'Lamp' Turning ON.
[D][switch:055]: 'Lamp': Sending state ON
[C][i2s_audio:024]: Setting up I2S Audio...
[C][wifi:038]: Setting up WiFi...
[C][wifi:051]: Starting WiFi...
[C][wifi:052]:   Local MAC: D0:EF:76:13:DC:C8
Has anybody else encountered this issue and perhaps found a solution? It is kinda disappointing having bought this supported hardware and just realizing it doesn’t actually work when trying to build a project.
I haven’t encountered this issue. It works fine for me on an ESP32-nodemcu and a max98357a with the following config:
i2s_audio:
  i2s_lrclk_pin: GPIO25
  i2s_bclk_pin: GPIO26
media_player:
    dac_type: external
    i2s_dout_pin: GPIO27
    mode: mono
I also have it working on an esp32-s3-devkitc-1
i2s_audio:
  i2s_lrclk_pin: GPIO6
  i2s_bclk_pin: GPIO20
media_player:
    dac_type: external
    i2s_dout_pin: GPIO8
    mode: mono
You seem to be missing connection on the Din pin from Dout on the esp32
This issue might be related to network access to the media file. Does your media URL play correctly when you paste it into a browser?
