That may be the case. I’m not saying they maybe don’t work for some folk. Simply that they work for me.
Here is part of my network. The two bulbs are both IKEA. The light sensor is a Xiaomi lux sensor. The window sensor is a Xiaomi window sensor.
Hi all,
I’ve add my inner plug, but it seems that my Xiaomi sensor stay connected to the conbee, even if I’m pretty sure connection to the inner will be more powerful in range etc.
is there a way to change that ?
No, you can’t. You can try removing the sensor and turn off all mains powered devices except for the innr plug and pair again. If you are lucky it will route through the plug, but even if it does, it might as well change the next day, routes are dynamic.
I will try to remove the cell of my sensor … because one off my sensor is disconnected (far away from the Connect) but the cell are new… maybe make an on/off will connect it to the innr plug
